Type of Grinder to use
jbogacki
Im getting ready to start the planning.
I was going to acid etch but decided i might as well rent a grinder and do it right. My rental place said a turbo 7" was the way to go. What types have you guys used and what works the best for a newbie?
Shea
California
The Diamabrush rental with a floor maintainer from Home Depot works well. Plus, it's more forgiving than a 7" grinder.
benchracer1
ramona, ca
I second the diamambrush. I had both the prep and removal wheels. I found the removal wheel very aggressive and it was a job for me to handle. The prep wheel was a bit easier to handle but took a bit longer to achieve the same results....Steve
accelerus
I'll need to rent a diamabrush in the coming weeks to get ready for my epoxy project. The few calls I made to home depot were a bit weird.
The machine rental itself is pretty cheap, but they told me I basically had to buy my own diamond blade and the total price was going to be something like 300+ dollars? Is this legit? or did the person working that day just not have a clue what I was talking about?
fenderzig
From my experience, you were misinformed. My local Home Depot rents the floor maintainer separate from diamabrush but I could also rent the diamabrush and didn't have to purchase one. I think my total out the door for 4 hours was around $120-$130.
RogueFab
Oregon
I would suggest calling your local Home Depot's and ask them..
My home depot tried to rent me a 7 inch hand held angle grinder. No wheel included, that's another $140. No thanks.
Equip rental places have the stone type floor machines for about $100/day. They are the way to go.
benwah
Crested Butte, Colorado
I only said Home Depot because it was already mentioned at the top of this thread. But definitely, if you can find a cheaper place, use it. I have a BLASTRAC / Diamatic wholesaler by my office that I use and it whoops HD's ***. But that obviously isn't an option for everyone.
Trey T
Houston, TX
I rented an EDCO w/ brand new 10" disc from HD recently because HD nearby ran out of the Diamabrush. My friend whom is familiar with the regular floor polisher/sander came over to help and he said the EDCO machine is much harder to use. We tried couple methods and just stuck with the push and pull method.
We spent 2.5hrs grinding it in two passes. I wouldn't rent it again if I have the choice of using the Diamabrush.
LegacyIndustrial
deerfield, IL
do they have a vacuum attachment for the Polisher and diamond brush?
For some reason THD opts for the lesser machine, minus the shroud and vac outlet.
We sell the unit with the shroud and it is awesome. Connect to a Dustless Shop Vac and breathe easy.
accelerus
as I slowly get my garage together (gotta do a bit more drywall work) one question I've had when it comes to grinding... is what's the generally better way of doing things?
Should I paint my garage first (walls/ceiling) first THEN grind? I know I'm going to be making an insane amount of dust. The paint I'm using is semi-gloss so it would wipe clean and easy. (might be easier to wipe it down after being painted vs wiping down bare drywall)?
Thanks!
Jeff
600SL
Connecticut
When I did my garage last year I had to remove old Epoxy. I rented an EDC unit with Diamondsert (sp) blades Rental was about $150 had to buy one set of blades for about $300. It worked very well but was very expensive. This year since I am on bear concrete I will be using the diamond brush from HD about $50 per day + $50 for the wheel.
