3/8 drive head in 1/4 ratchet body
ADSR
Guys, i've seen a few pics posted of these ratchets. Are these custom made drives, or can they be bought like that?
I've run in to some places where i need to turn a bigger socket, but no room for a 3/8 ratchet. And i'm not talking about needing this ratchet for breaking bolts loose. I'm talking once the bolt is broke with a wrench, just needing to turn it with very little pressure on it.
If i can't find one, maybe buy a williams 36t 1/4 flex and a 3/8's repair kit and have it machined to fit? Or will the drive be hardened and useless to machine?
Thanks guys.
Here's what I've put together so far as a comprehensive list of 3/8" drive in 1/4" body ratchets (in no particular order). Feel free to let me know what's missing, and I'll continue to update as needed.:beer:
SNAP-ON
FC72 3/8" Drive 72-Tooth Compact Head Ratchet
FCF72 3/8" Drive 72-Tooth Compact Flex Head Ratchet
RKRFC72 3/8" in 1/4" Body Kit - Snap-on 72T "Dual 80" Series ratchets
FHCNF72 3/8" Drive Compact 72T Compact Swivel/Roto Round Head Ratchet
RKRFHCNF72 3/8" in 1/4" Body Kit - 1/4" 72T Swivel/Roto Round Head Ratchets
FHC737 3/8" Drive Compact 39T Compact Swivel/Roto Round Head Ratchet
RKRFHC737 3/8" in 1/4" Body Kit - 1/4" 39T 700 Series Swivel/Roto and Round Head Ratchets
FCY72 Hi-Lok "Compact Head" 3/8" Ratchet (72T) (Hog Ring retention in 1/4" QR body)
RKRFCY72 Hi-Lok "Compact Head" 3/8" Kit works with 72T 1/4" Quick Release Ratchets
FC936 3/8" in 1/4" Body Ratchet (36T)
FCF936 3/8" in 1/4" Body Flex Ratchet (36T)
RKRFC936 3/8" in 1/4" Body Kit - 36T Series Snap-On and Williams Pearhead Ratchets
FM70 3/8" in 1/4" Body Ratchet (20T)
FM711 3/8" in 1/4" Body Flex Ratchet (20T)
RKR70FM 3/8" in 1/4" Body Kit - 20T Series Snap-On Ratchets
WILLIAMS
RKRFC936 3/8" in 1/4" Body Kit (Snap-On) - 36T Series Williams Pearhead Ratchets:
M-52EHA, M-52EHFA, MB-52EHA
WRIGHT
3430 3/8" in 1/4" Body Ratchet (45T)
3440 3/8" in 1/4" Body Flex Ratchet (45T)
33430 3/8" in 1/4" Body Ratchet, Black Industrial Finish (45T)
3432 3/8" in 1/4" Body Kit - Wright 45T Series Round Head Ratchets:
2426, 2495, 32426
SK
45173 3/8" in 1/4" Body Ratchet, 4.5" Length (60T)
45171 3/8" in 1/4" Body Ratchet, 6.5" Length (60T)
3767 3/8" in 1/4" Body Ratchet, Flex Head, 6.3" Length (60T)
45173-2 3/8" in 1/4" Body Kit - SK 60T Round Head Ratchets and Thumbwheel:
40970, 40971, 40972, 49270
CORNWELL
TR32 3/8" in 1/4" Body Ratchet (30T)
TR32H 3/8" in 1/4" Body Comfort Grip Ratchet (30T)
TRF42A 3/8" in 1/4" Body Flex Ratchet (30T)
TRF42HA 3/8" in 1/4" Body Comfort Grip Flex Ratchet (30T)
TR32RK1A 3/8" in 1/4" Body Kit - 30T Series Cornwell 1/4" Ratchets:
TR3, TR4, TRF4, TR3H, TR4H, TRF4HA, TR3S, TR301, TR301H,
MAC
XR5MK 3/8" in 1/4" Body Ratchet (30T)
??? 3/8" in 1/4" Body Kit - 30T Series MAC 1/4" Ratchets:
MR5K, MR5FPA, MR6FK, MR6PA, MR8FPA, MRS7FPA, Proto 4750
MATCO
BFR472T 3/8" in 1/4" Body Ratchet (72T)
BR5T 3/8" in 1/4" Body Ratchet (36T)
PROTO
J5248S 3/8" in 1/4" Body Ratchet (24T)
J6064RK 3/8" in 1/4" Body Kit - 24T Series 1/4" Proto Ratchet:
4749
KOKEN
2725z-3/8 3/8" in 1/4" Body Comfort Grip Ratchet (36T)
TONE
RH3CH 3/8" in 1/4" Body Ratchet (72T)
RH3CHS 3/8" in 1/4" Body Stubby Ratchet (72T)
RH3FCH 3/8" in 1/4" Body Flex Ratchet (72T)
RH3FCHS 3/8" in 1/4" Body Stubby Flex Ratchet (72T)
RK-RH3CH 3/8" in 1/4" Body Kit - Fits RH2 Series 72T Ratchets:
BFHtime
Snap-On makes it. I do not have one, but I have a friend that does. I usually use extensions and swivels to into tight spots. Where they don't fit there are low profile sets. It is on the web site.
A
ADSR
Take a look at it as well. I have a feeling the wright will be a bit cheaper tho. :lol_hitti
Spudland_Dave
Maine
I've got a FCF72, bought it because there was all kinds of hoopla here about having 3/8" heads in 1/4" Bodies, and my SO guy had em on special...glad I did, its very very handy. I use it way more then I thought I would.
JDon99
Desoto, MO
I was getting ready to mention the FCF72 as well, it's on my to buy list...it's a little longer than most of your typical 1/4" body 3/8 drive rats.
nesw20
yep, i've used one (not mine, but a tech i work with frequently) and it's AWESOME. i always do a double-take when i see it, though! :lol:
BFHtime
The difference is the head of the ratchet is more compact. It is a 1/4 inch head with a 3/8 drive. A stubby would have a 3/8 head that is very short in regards to the handle length.
BFHtime
I have one that is 1/4 inch on one side and 3/8 on the other, very handy.
I have one of these, sometimes the drive on the opposite side gets in the way, when in a tight spot. It is not bad. Mine is a cheap one though.
mailpup
Los Angeles
They also make the same kind of thing in an air ratchet, 3/8" drive guts in a 1/4" drive body. Very handy in tight quarters. Mine happens to be Mac branded (probably made by IR) but there are other brands, of course.
A
ADSR
A lot of great info with part numbers and links.
I really appreciate it, guys.
Thanks!
rshadd
Doylestown, PA
Snap-on 3/8" drive COMPACT Flex Head Ratchet in 1/4" body FCF72
Here's a pic comparing the FCF72 (above) to the TL72 (below)
The FCF72 comes in handy when used with bit sockets, since bit sockets are 3/8".
A
ADSR
Thanks rshadd!
That's a great side by side comparison.
shockwave
Marietta,ga
Snap on FHCNF72 has been a go to of mine for years also I have a thlfd80 that I swapped out the guts from fcf72 that work great
ihateminimumwage
After some reading on here a while back, I really wish Snap-On still offered the 3/8" drive-1/4" body rebuild kit they used to have for the 36 tooth ratchets. Would love to pick up a Willaims 1/4" flex head and throw one in.
Kent_B
MI
We sure could have used one when we were taking spark plugs out of my son's DOHC Subaru.
A
ADSR
That was my thought as well, since i have that rat on the way.
yhprum
Brisbane Australia
Here Are the SK ratchets. The 3/8 is SK part number 45173. What I really would like is a small 1/4 drive SK roto ratchet!
