3/8 drive head in 1/4 ratchet body
mechanicalmoron
I'm not understanding how anyone doesn't think that's just "stubby".
Maybe a stubby with a little, delicate body. Maybe one that shares head size/mechanism or a body with other ratchets of other sizes.... but it's still just a small stubby ratchet.
Loscaldazar
Because I love spread sheets.... PM me if you have updates to it.
Askme42
Goreville IL
I had a hard time with it also but it's the head size that's smaller that makes the difference. Or so I'm told ;)
chrenan
Canada
I thought that too until I got the Proto version. Trust me, a 3/8 in a 1/4 body will make you reevaluate how you use tools, how you live your life, absolutely everything will change. At first you think "what the hell, it's just a tool". Then you realize "wait no, it's not just a tool, it's a state of mind". Only at that point do you take your first step down the path to enlightenment. It probably sounds like I'm underselling it, but I'm not.
carcajou
SW Alberta
My life too had a certain meaningless to it. Then one day i found the proto version. Since then my wife has said i am much happier, a better person. Thank you Proto
Add the 1/4" rebuild kits in 3/8:
J5248S Kit: J6064RK width: 1.034 - thickness: .378 (head only not the drive)
BDT/NWMN
Erskine, Mn
I have a SnapOn FM70 that I bought a L o n g time ago..
It is a true 1/4 drive ratchet with a 3/8 male drive.. total length is 4 3/8"
That little ratchet gets used allot.. This past weekend; it was paired to a SnapOn flare nut socket ... Regular flare nut wrenches were too long to get into a rather confined spot.
A
ADSR
Post a pic if you ever get the time!
Looks like you can still buy a repair kit for it as well!
RKRA70FMA
slip knot
Texas gulf coast
Heres a couple of pictures of the wright 3/8 in a 1/4 body that I got from epstiens. Have used it a couple of times. works very well in confined spaces. This was my first Wright ratchet and I was impressed.:thumbup:
thebeekeeper1
Illinois
I have one too--found it on the road in like new condition. I don't need/use mine much but when I do it's REALLY handy. Great little tool. :thumbup:
vandezand
Cedar Rapids, Iowa
Just letting you know there's a snappy 3/8 drive in a 1/4 rat in the classifieds. Its not mine, I just saw it when I was browsing tonight
BDT/NWMN
Erskine, Mn
my Std 1/4" drive TM70b is 20 T. :dunno:
20 tooth in that one would be a headshaker for sure... this old FM70 is 30 clicks......Snappy put a kit in this ratchet about two years ago.
For ten bucks, it should be worth a try putting the same kit in your TM70B..
Jason280
I have a flex head SK 1/4" ratchet that's 3/8" drive...very compact. I've had it for a while, but still haven't found a reason to use it yet...
chrenan
Canada
This is a perfect situation, please allow me to interject, you are literally on the tipping point of enlightenment.
So you've faced a conundrum in the garage and are presented with a choice. Do you choose the 3/8 ratchet or the 3/8 in the 1/4 body? It's simple really, do you want to process that question, or do you want to question the process? One choice will provide you with an actionable solution to a complex problem, the other choice will lead to a complex solution to an actionable problem.
Is the answer clear? No? Good, then you are ready to learn and begin your journey...
4x4gearhead
New Hampshire
Most major companies make them. I have a matco straight handled one but have seen snap on, sk, proto, Mac, and wright versions.
A
ADSR
You make my brain hurt. But i kind of like it! lol:rocker:
sk farmer
nd
the first two pics are 3/8 drive compacts from sk and titan. the titan is a roto head and quite similar to the old sk tuff1 and palm control ratchets. i highly recommend it.
the second two pics are sk 3/8 drive stubby ratchets.
gearhead1
NC
I have the Snap on FCF72, it wasn't cheap, but I couldn't get it from Craftsman (before China). Most of my specialty stuff is Snap-on because of that. It is really nice on the front wheel drive cars where everything is tight. It was worth it.
OK, the kit from SO came in: No plate, so things get more difficult...
I know Proto generally ships a plate with there kits, if SO does it was either omitted, or was deliberately left off so you can't "upgrade" an older 1/4" ratchet...
To make it even more difficult, the hole needs to be about 5.031 or so. the 3/8" hex was .496 corner to corner, if they had gone with that the hole could have been .500...
I'm still OK, as I have 3 17/32 drill bits (.53125), but :wtf:
FYI the back side hole (and the front of the 1/4" drive) was 3/8... :dunno:
Now I just have to decide which one to do.. Probably the only chromed one.
I also took a look at the Proto and dang its a close cal there too, except the back hole is oversize; maybe a press fit bushing onto the drive gear? :dunno: Something to think about.
:soapbox:
Well now I've done it: I broke the ****** plate. I set it up for drilling (which was not going to be easy) and I stupidly (in retrospect) set up an angle vise 90 deg up, got it centered and started drilling. The plate is hardened so I know I'm eating the edge of the bit as I go, and I snapped the little mother off. :tantrum2:
1950mercury
metro detroit
:soapbox:
Sorry to hear that,that *****.
Thanks for the update i have the same snapon ratchet and i was waiting to hear if it would work
ChevyEFI
Phoenix, AZ
Here is why:
Stubby SK 3/8: http://www.amazon.com/dp/B000FAL450/?tag=atomicindus08-20
Stubby SK 3/8 flex: http://www.amazon.com/dp/B00062LLP0/?tag=atomicindus08-20
Here Are the SK ratchets. The 3/8 is SK part number 45173. What I really would like is a small 1/4 drive SK roto ratchet!
RIP SK 3870. :(
1950mercury
metro detroit
Tm70c2 is the part# for the tm70b cover plate (1/4" drive) it would be nice if they sold the 3/8.
If you look for parts for the fm70 nothing comes up. Is that the correct part #
jonti48310
I have the SK 3/8 in the 1/4 body and use it all the time. Great ratchet to have. Comes in handy.
OK, a little better news:
The 3/8 drive plate IS available: FYI it is NOT a warranty part (I'm fine with that)
P/N: FC72-2 (For FC72 ratchet) and costs $7.55 (It does NOT appear on there web site, call Customer support to order)
The rebuild kit was $10, and was P/N RKRA70FMA.
So I'l be into the conversion for under $20.
I should have my part this time next week
