Show off your lathes
PMD6
Mine is a Grayson 3.5in. Probably dates from the 1950s
The counter shaft / motor mount is a mock which will be replaced by a frabricated version once I have found some light weight pulleys
Sent from my GT-I9300 using Tapatalk
drb007
WI
You didn't specify wood or metal...
dr_clyde
Holland, MI
Sheldon R15 precision toolroom lathe. Swings 15" over the bed and turns 60" between centers.
Guster
Auckland, New Zealand
This was my first, a 9x20 that I got from a company that never used it. It was still strapped to the shipping pallet and coated in cosmoline when I picked up.
Sold that a few years ago and upgraded to a 12x36 for pretty much the same price. Compound needed a little work to get it shipshape but can't complain. This is the day I picked it up.
Since added a 5c collet closer, Dickson/Rapid style QCTP and considering a DRO later this year.
FunkyfullWidth
Three Rivers, ma
I bought this jem for 80 bucks at an auction several years back. It's an atlas 618 with timken bearings and came with a set of jacobs commutator chucks. It took along time to get it functional, I had to wire a switch into the motor, source a chuck, and get a tool post for it.
This is right after I bought it.
And it's final resting place. I've stripped it down since this picture, painted a few small parts and cleaned it up. But you get the idea. I also got an older huot top and bottom box that I have on top and underneath the table for storage.
Deskmechanic
Long Beach, CA
Here is my too-big-for-my-shop Sheldon 10" x 64" bed. It's a bit underpowered with the 1/2 hp motor but I have a 3/4 hp Walker Turner that will go on it one of these days.
Sune
Denmark
I just bought this one :thumbup:
The lathe has been used for wood working thats why it came with a homebuildt rest.
I will only be using it for metal when I have cleaned out the wood chips :lol: - already have a lathe for wood
Fretters
South Yorkshire, England
The counter shaft / motor mount is a mock which will be replaced by a frabricated version once I have found some light weight pulleys.
If you decide to let those pulleys go if you change them, (you're in the UK?),any chance I could have first shout on those? Trying to build up my collection of flat belt kit for the future lineshaft system, plus most of my stuff is flat belt drive.
Nice machine. Up until recently I had a Warwick, (I still have access to it to use it if needed, once he sets it up), which is pretty much the same machine. Only reason I let go of it was that I decided to dedicate my time to getting the larger machines sorted instead of going over it and fettling that one, plus I really needed to make some space. :D Made no end of bits with it whilst it was here though. They can be a bit of a nerve tester with things like parting off, but they're decent machines.
P
PMD6
Sure - I've found a pulley for the motor just need to find the larger one now
Sent from my GT-P7510 using Tapatalk
Fretters
Cheers. :) One thing I found was well worth making for that lathe, (it was the first thing I made with & for mine when I originally got it set up), are some headstock oilers. I just made mine out of some brass fittings, and the caps were made from some 10mm brass bolt heads. Saves having to oil the headstock as frequently. These were them fitted:
The bit on the left is what they were made from.
They were made as a snug push fit, and had a bit of paraffin lamp wick in the bottom hole to slow the flow somewhat. They worked well.
sr71
Here's my old Atlas - been a good lathe for a lot of years ....she needs a bigger brother though - perhaps a nice Monarch similar to posted earlier
Sune
Denmark
A funny thing is I can't seem to find any makers marks one mine. And has mine been converted to? Seems as if something is missing above the drivebelt discs..hmm
P
PMD6
Picked up a Raglan Loughbrough Training Lathe last night. It was listed as a rusty lathe in the local ads for £30.
The pic below is after an hr or so work with a power washers and wire brush. All bits not move freely.
I'll probably end up keeping it
59'trump
I will post pics soon but I have a few southbend lathes that I would like help putting some values on. I'll try to get back soon! Thanks all!
Carla
MEMBER EMERITUS
Alright, here's mine.....
1941 vintage ex-Navy 14x30 Monarch, and 1966 vintage EE.
These are 'left-overs' actually, from the pre-CNC era, which I had an interest in a small machine business. When that business was shut down, I kept these little ones as 'home hobby shop' equipment. They still run well, and will reliably hold reasonable commercial tolerance levels.
cheers
Carla
Photos, if the link works......
(would someone who has the relevant computer skills please post the photos here for me?)
Carla
MEMBER EMERITUS
My royal flush!
Monarch 10EE, 13EE and, 2013 Series 62.
Steve
Oh, my, the famous 13EE.......'the ultimate lathe'
Steve, you've gotten yourself the very best lathes ever built......'well done' on being able to have those...... : )
(what was the job on the electricals of the 13EE like, to get it running?)
cheers
Carla
Steevo
43.49600, -112.04300
I picked mine up for $600 a few years ago.
Craftsman/Atlas 12x36, and came with a lot of tooling as well:
I use the heck out of it. It is amazing how many things "need a lathe" when you have a lathe.
Tim338
Here is my Southbend 9A I restored late last year.
metaldad
nw indiana
some beautiful restore jobs, gents!
i gotta get an olde cman wood lathe out of storage. been unused for.......... at least 25 years
P
PMD6
Scrubbed up ok. Just need to find a tail stock and tool post now ImageUploadedByTapatalk1406906805.157315.jpg
ez-duzit
Marina del Rey
I'm in the cheap seats. Got the Logan 2557V variable speed 12"x35" lathe and Index Super 55 mill for $2k. The lathe had a few boxes of tooling but nothing for the mill. The lathe motor had already been replaced with a new single phase, 115/230 volt.
arkyengineer
Northwest Arkansas
My new Monarch Series 61 13"x30"
G1K
I like your paint job I my have to consider that color when I get around to repainting mine.
a South Bend 9"
and a Power King rescued from the trash prior to being restored.
