Falcon67
We just acquired a new 3500w genset for our race trailer. After doing a bit of reading, I'm clear on the "RV" panel in the trailer being a subpanel, and not having the neutral and ground bonded together there. And, that the ground wire needs to be bonded to the trailer framework. This will be a 120V 30A only type setup, using a standard RV plug/socket. The question comes in at the genset - I'm picking up that a "cheater plug" needs to be made for the genset since it is a free standing unit and will not have neutral and ground tied together.
http://www.noshockzone.org/generator-ground-neutral-bonding/
Seems right. I still worry that because we have a trailer sitting on rubber tires, a truck sitting on rubber tires and a generator sitting on rubber tires - who/what/where is going to trip if there is a fault between the hot and the trailer frame. And, will the normal GFCI plug function correctly in this setup. Have not bought any parts, no work started - Comments welcome.
Very, very few people that don't have some sort of generator. Many cars still don't run alternators, so there is a lot of battery charging going on between rounds. That's the one thing we don't have to run.
