Mini Split for Apartment
bedn0009
Hudson, Wisconsin U.S.A.
Hello,
I am remodeling an apartment I have, and was wondering if a minisplit might make sense for the upper level... and if so, I have some specific questions (before this site I had never heard of such a thing).
1. I need to supplement the heat and cool 2 bedrooms that are on the third floor of this building... it gets both very warm (summer) and very cool (winter) because of the distance up to these bedrooms.
2. Does a minisplit make sense? I'd have to have it installed via electric only.
3. Total square footage is about 350 - including both bedrooms.
4. If I mounted it centrally, how could I duct it to the individual bedrooms?
5. Any product recommendations that would fit my scenario?
Thanks!
theoldwizard1
SE MI
1. I need to supplement the heat and cool 2 bedrooms ...
Much cheaper than electric resistance heat to operate.
I don't understand the second part of this. Typical installation would have 240V running to the outside unit (small units run on 120V) , 2 refrigerant line running between the inside and outside unit, 120V power to the inside unit and a condensation drain line from the inside unit.
Some ductwork would be required. You could also install a dual zone (2 interior units) heat pump, so no ductwork would be required, but it would cost more.
Stick with a name brand sold and serviced by a reputable HVAC contractor. Mitsubishi and Fujitsu are probably the 2 biggest.
cspcrx
Phoenix, AZ
with a space that small a portable until that you could just put away when not needed may make more sense. Also if it is an apartment, I think of apartments like the type that you rent that are in a large building, they may not like you drilling holes for a ductless unit.
