Low profile ratcheting screwdriver
matt stott
Boston, USA
CZ_Greatwrench
I have a Schroder set and like it alot, I tried finding a link and couldn't find it. Looks like maybe they don't make it anymore...I bought it about 4 years ago.
I did have the Craftsman before, it got the job done but the ratchet handle was too stiff and course for my liking.
nicksnothereman
In the Mojave
Wow. On 2 different applications today, I needed to use a P2 screwdriver bit with a 1/4" wrench to remove/install screws because of the tight access.
I have something that looks a lot like one of these:
http://www.ebay.com/itm/24pc-Right-...l-Set-Socket-Wrench-7-Extension-/301001492261
And it was too big.
Anyone Got recommendations of something even thinner?
If that's too big you probably should be disassembling stuff before you go at it.
You could use a throwaway (i.e. crappy) p2 bit and cut some of the non-driver part off with...whatever (I don't got a torch so maybe a hacksaw?) and that would be lower profile. Also could just try to turn the bit with a pair of pliers (sometimes that can work; vise grip or groove joint would be the goto) instead of using the driver itself. I don't really comment on how other people work, different strokes for different folks but sometimes you need to re-visualize what you're doing to get it done; it can end up being more of a process but it ends up sticking with you if you can shirk the "I need tool x" and focus on the "I have tool x, how do I get it done". Depends on what you got in your arsenal of course and what you're willing to do with it.
bart1
Alabama the Beautiful
Husky unit still available as VIM.
Cut down standard P2 bit.
If that is not low enough, Japanese company Anex has some non ratcheting versions.
Triple macs
I run into this fairly often. I have both the Stahlwille and Felo bit holding ratchets. I bought the Stahlwille years ago, but now it is stupid expensive. The Felo is a bent handle and the head is smaller. I like and use both. I also use a 1/4 X 5/16 flat ratcheting box wrench and just insert the bit into the 1/4 end when things are really tight. But of course, you have to back up the end of the bit with your finger to make that happen.
dede2897234
Northern, Ohio
ajchien,
Here is a recent GJ thread about bit ratcheting screwdrivers with many low profile options: LINK.
Snap-on manufactures a 17 piece low profile bit set for $60.50 (with free shipping): LINK. If it is too much money, you can buy the bits (flat, phillips, hex, and torx) individually by clicking on the "Sets/Members" tab.
Dave
A
ajchien
Los Angeles, stuck on the 60 freeway.
A
ajchien
ajchien,
Dave
Great links, I've got some comparing to do!
Danglerb
SoCal
I have the GW microdriver set, but I'm always looking at neat low profile bit drivers. The GW bit adapters combined with a full set of obstruction wrenches and indexing head wrenches should beat just about anything, so I have those too.
A
ajchien
Gearwrench sells these:
http://www.amazon.com/dp/B000HBAI1I/?tag=atomicindus08-20
But they're a bit pricy (IMHO) for what they do.
This set may be a bit more reasonable since you're getting the adapter, bits, and a 1/2" reversible wrench out of the deal too:
I wound up getting those adapters last week, and used them today to replace a blower motor transistor under dash. Man, it's nice to have air conditioning in the car again.
bob15
Northeasten, CT
The Chapman kit is a very handy kit to have. I would recommend everyone has a set (have two sets myself, one at work and the other at home). It is well worth the money......
ChevyEFI
Phoenix, AZ
Kind of off-topic but these looked ultra low profile compared to the options posted so far.
I wonder the OEM.
senlow
Wheat Ridge, Colorado
Dust Devil
Right next door to hell
I tried to buy the snap bit ratchet the one that is like a t72 head and these are so much lower profile.
The carb plate on FCR carbs commonly found on 450 mx bikes and the intake manifolds on sea doos are 2 places these shine. Many more but these are two standouts.
dede2897234
Northern, Ohio
Dust Devil,
Are you talking about Snap-on model# 112RTSM which includes a ratchet resembling a T72? It is the low profile, pass-thru ratchet and socket set (5 to 13mm) with an included bit adapter. Here's a link to it on the Snap-on website: LINK.
The bit adapter was designed to be used with Snap-on's low profile bits: LINK.
Dave
Rickedstyles
Conroe, TX
If you don't need one for every day use and/or its the wknd and need it now Lowes has a kobalt set for under 20$ that is fine tooth..
IOWNJUNK
General Hardware Mfg co
#807 & #807-x
Thinnest I have ever seen, and they ratchet too.
Danglerb
SoCal
What worries me is that somebody out there is looking at those ANEX tools and making stuff that needs them.
franzdom
NC
:spit:
I am a design engineer, we are always trying to make things fit in tighter spaces, taking into account service and manufacturability. There is no doubt that what you speak of is true!
dgxlh
western ma
Funny that I see this thread today because yesterday while.I was at sears checking out the sales I ran into.the gear wrench set for 20 after some reward point things it was only 10. Been wanting one of these for awhile but could only find it for 30 bucks.
BFHtime
I used a 1/4 low profile ratchet from Snap-On with the bit holder. I used a average size P2 bit in it. The low profile bits would give it more clearance. For he money that Canadian set up might be a good deal if price is prohitive on he Snap-on.
