Rudyjr
Buddy just had his home inspected prior to sale and this item is listed as needing repaired:19) Safety, Repair/Replace, Evaluate - Neutral wires were doubled or bundled together on the neutral bus bar. This is unsafe due to the need to turn off multiple circuit breakers to work on any of the circuits using these wires. A qualified electrician should evaluate and repair as necessary.
I am at a total loss on what the heck this guy is talking about. I have seen a ton of panels that had more than one neutral under a screw on the bus and was always told that this was not an issue. From what I have found online it seems code on this may have been revised in 2002 to one wire. Can someone clarify this for me? Thanks, Jim
as they would still be connected to a common mount, single or double what difference can it make besides a possible loose wire? how would this require you to turn off multiple breakers?
BTW, has nothing to do w/ you been calling OR, that for close to 30 years, but if Oregon ever adopts a sales tax, then it will be really deserved.
