KMScott
I've seen pics of vises with those pins you mentioned and mine does not have them. Just the set screws. The openings measure 2 7/8 x 2 7/8, with the depth at about 3". I've pm'd the seller and asked for the jaw measurements. If they fit then I'll pull the trigger. Still not sure what purpose the clips on the back of the jaws serve... Anyway, thanks drivesitfar!
Also, would you consider this vice a good candidate for an electrolysis bath? Been looking for an excuse to build one!
Here is a drawing of three different C1 Pipe jaws, I add the holes for the 3/8 pins, and a 1/4:20 thread in case the C1 jaws accepts the clips. Yours will work for the two pipe jaws you showed in a earlier post but you might need a spacer. I had to build a spacer for the C1 that Macklin needed for his C1. Greg is a member here. If you need a spacer then make it to these dimensions .188 x 1.735 x 2.735. I hope this helps you make a decision.
