Backlight
Hoping someone can provide input into a garage floor install that did not go quite as intended.
I had my 32' x 32' garage floor poured yesterday, 6", 4500PSI with fiber on top of 2" of R10 insulation, rebar and 5/8 PEX for radiant heat. The pour went well and I was happy with the finish. Today the contractor came to saw cut the floor (it was actually one of his staff). 3 of the 4 cuts look 'ok'. Something went quite wrong with the 4th and arguably most important cut. The cut down the middle from front to back right in the middle of the double door has a huge snake in it. It's out 14 - 18" front to back. It looks horrible and considering I have OCD it's going to be hard if not impossible to look at it going forward.
The person who did the saw cut acknowledged something went very wrong. He actually said he felt sick to his stomach about the result. Possibly because I asked him at the beginning to ensure the cuts were dead on and he said he's never had an issue in the past. I'm not sure exactly what happened, might have been an issue with his saw.
I spoke with the contractor/owner, he had spoken to his employee and knew about the situation. We have to come up with a solution to the issue. Short of ripping the whole thing out and starting over what options are available? I was thinking filling the saw cuts and then doing a high end epoxy coating might be an option? Or perhaps filling the cuts and then a diamond grind? Finally maybe a floor covering of some sort? Any of the aforementioned will cost the contractor allot less than ripping it out and starting over, especially considering I have 3K in material under the concrete.
Any thoughts on the best course of action?
Thanks in advance….
Thanks in advance….
