My 32x52 Garage/Workshop build thread
G
gmgrunt
mid Michigan
Thanks for the kind words....Brent, my other project is a 34 3w coupe, chopped 4", quickchange, 401 nailhead buick 5spd highboy. :)
-Brent-
Utah
Awesome! Someday I'll grow out of my 26-31 Fords and and get a big boy hot rod! I'll be following along, be sure to post a bunch of pics.
G
gmgrunt
mid Michigan
More siding pics, the board and batten is done. The area left incomplete is for a little stonework. the lap and B&B are Nichiha fiber cement products and the trim boards and Shakes are LP smart products. I have some cedar brackets for lights and window trims. Paint next month, the colors you see in the pics are the primered colors.
G
gmgrunt
mid Michigan
Some recent pics of paint, light brackets, trim and some cool morning low cloud shots.
Having a good time in the lift!
My wife doing the custom paint. base color , then wiping on a darker brown to get in the deep wood grains...and wiping most of it back off.
It gives it a 3 dimensional look....more realistic.
probably should have unhooked the quad before leveling the lift up! :)
If you look closely, you can see the roof of the Garage at the end of the road.
Absolutely B-E-A-U-T-I-F-U-L morning!!!
Motoman1100
GA
Thanks for the pics! What an awesome spot, I would just stand there all day enjoying the view!
-Brent-
Utah
Man, what a beautiful building in a beautiful setting.
Really great work and attention to detail.
G
gmgrunt
mid Michigan
Moving some stuff in and getting the bathroom up and running. Pics of the "Manity" with oil pan for sink bowl. Got electricity, water, toilet, Need to hang some drywall now.
PurdueSD
Indiana
Congrats! Beautiful spread, I am particularly interested to see how your layout works out. Ive been back and forth on divided vs open shop for the same reason as you.
G
gmgrunt
mid Michigan
After having my current shop wide open and all the grinding grit and primer and paint overspray all over everything including my mill and lathe I'm convinced keeping the dirty areas isolated will be a good thing. Besides it creates more walls to hang stuff!! lol:lol:
PurdueSD
Indiana
I hear ya.
< my last shop was 30x56 with no walls. A couple hot rod projects were enough to continually coat everything. Im am worried about loosing the open floor plan for stuff like pulling a cab off a frame (or minibike donuts):rocker:
G
gmgrunt
mid Michigan
PurdueSD. I just read thru your build....Nice shop! I like the wood siding used inside rather than drywall, it's been a few years since your build, would you still use that if you had it to do over again? Thanks, Jeff
PurdueSD
Indiana
Thanks, I really miss my old shop!
I used a masonite type hardboard siding. Its a little cheaper than LP smart siding but not quite as durable. I would never use masonite type siding outside though!
Yes, id use it again. I liked how it gave the walls some texture. Thought it added some character. The main reason i chose it was I hate drywall finishing. The panels came pre-primed gray and i didn't even paint them. I found some gray deck screws to hang it with. It worked out really nice. Also it was kinda handy that since i screwed them on, they could be easily removed. There were a couple times i removed a sheet or two to add some wiring.
CGT80
IE, SoCal, USA
How the heck do you wash your hands in that sink? :confused:
I don't see a spout for the faucet.
The garage looks great.
You are going to paint the drywall in the bathroom, right?
G
gmgrunt
mid Michigan
Good observation....the faucet is not installed yet. Waiting to get the drywall done and painted then I will finish and mount the faucet.....but I think you will like it! stay tuned. :)
