balane
Thank you. That is Valspar Satin Leafy Green. It's the closest color, in a spray can, that I can find to the original Wilton color from the early 40's.
Here's a little 2.5" Chicago on a very uncommon clamp mount base. Autopts tells me this is the rarest base available on Wiltons. The date is 1947.
The vise itself is in truly excellent condition but unfortunately the base, at some point in time, was broken and then brazed back together. It broke where the clamping leg connects to the swivel base. It came to me with a huge, ugly, lumpy braze that looked like a disease was growing out of control on it. I spent more time than I care to think about smoothing it back into shape. You can only tell the braze exists now if you completely remove the base from the workbench and examine the underside of it. I'm pleased with how it turned out, I did not expect it to look this good when I first got it.
Anyway, it's a very nice vise in the old Chicago mint green and the base is cool and completely solid in my opinion.
I'm not sure if your searched, but there was another vise that was described exactly like yours and sold a few months ago:
http://www.ebay.co.uk/itm/RECORD-NO...D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
It was believed to be a Record
And just in case you're wondering what I started with. This is how it came to me originally.
Edit: No type of filler used either, all shaping and sanding.
Just found this listed on CL for $15. Not sure it's worth the 3 hour round trip though...
Thanks everybody.
One complaint I have about it is just how smooth the repaired section is now. Sure, smooth is great but when you look at it next to the rough cast iron finish the rest of the vise has it really stands out. At least to my eyes it does.
So my question is, if you have some smooth cast iron in front of you is there a way to replicate the rough cast finish so it blends in better? I knew it was futile but I tried hitting it with my media blaster and tried the media products I had on hand which was sand and glass bead. It had absolutely zero effect on the cast iron as I knew it would and as it should be. There's probably no way to do this, eh?
Never tried it, but maybe a needle scaler?
The thought crossed my mind actually, at least the entire base but I'm like really, really done with sanding right now.Time to just hand sand the whole thing smooth...![]()
Yesterday and today I put together several handles ....
Do you pein the ends or just punch?
I'd be tempted to try the natural way and rust it. Hydrochloric acid sprayed on, (simply because that one has the most aggressive rusting attributes, from what I hear. I believe you call it muriatic acid over there), leave it to air for a day or two and then derust it.
I am slowly getting to the point of the actual painting of several of my vises. Yesterday and today I put together several handles including the 2 inch baby and the Wilton 800 for customers along with several Swivel clamps. Need a couple Aluminum/Bronze wear plates made for the Colombian's spindle's and then I can start the de rusting process. The Colombians are my practice restoration vises.
I pein the material into a 60 degree chamfer on the knobs, shoud hold up pretty good, this is how most of the vise makers did it except they used a punch press and did it cold.
Muriatic is a dilute form of Hydro. Used as a pool chemical quite a bit.
SNIP
Cheers. Muriatic seems to be the word I generally see the most when hydrochloric is referenced across your side, so I'd just assumed it was another of those translation things.It's called hydrochloric in base form both sides of the pond then, I take it?
Don't forget the most important tool you can have for painting vises. I suggest that you invest in the best quality display stump that money can buy, to compliment those outstanding jaws you produce.![]()
Balane is going to have trouble selling that beat up old Wilton he just finished. There was no way to attach it to the stump![]()
Hi Provincial. I did try sandblasting it. For sand I used the heaviest grit sand my gun will squirt and at max pressure. It just had no effect at all on the surface. The bondo idea is a good one. I like the idea of applying a textured surface and then painting over it. I was going to try a light spray of textured paint as well. Thanks for the tips and compliment.Balane, the best way to texture smooth cast iron to match sand cast is to sandblast with high pressure and very coarse sand. Barring that, a thin coat of Bondo and roll a piece of coarse sandpaper over it when it is still soft, but not sticky.
Nice job on the Wilton. A lot of work, but an unusual vise.
SNIP
Outlaw, you have a good condition standard 3 ear swivel base that will fit a Chicago 2.5" Wilton vise? Base is 4.5" diameter, mounting holes 3 3/8" apart center to center. If buyers are balking at a repaired clamp base then a trade would be something I could consider if your offer wasn't in jest.
I like the color very much but it's obvious they're grommets, no getting around that. I used grommets in the past and it always bugged me personally.
If you want to buy some cheap finger savers this link was posted earlier in the thread. These are good, affordable replacements that look as intended. Only come in black though so you'd lose the nice colors.
http://www.mcmaster.com/#neoprene-rubber-gauge-glass-washers/=t1ueay
balane the scaler is a good idea, you can play around with the air pressure to not beat the dents to aggressive. Nice job as usual on that rare 2-1/2 inch. I have been taking notes on everything you mention about painting.
Here's another source for fingers savers, not sure if these have already have been mentioned, they're kinda of pricey but if you only need one set then there not too bad. If he doesn't have your size you can probably ask him if he has others.
http://www.ebay.com/sch/inspectorhouse/m.html?_nkw=&_armrs=1&_ipg=&_from=
I used, for the first time, Hammerite's blue spray paint. In my opinion it destroys Rustoleum's hammer paint. Hard as nails and hammer finish comes out great.
