I've been wanting and needing a shop for many years. Over the years, I've built about a dozen racecars in my attached 2 stall garages. Finally decided to get a real nice place to work on my hobbies. Got the concrete down for a
36'x 48' a few weeks back. I'll be a Pinno built post on monolithic slab. I'm going with the Shallow Foundation Frost Protection insulation method. Insulated vertical sides of slab 2" of extruded foam and out around the perimeter 4' wide 2" thick.
Slab is a monolithic slab. 12"x12" perimeter beam with 4 rebar. Slab is on 6 mil barrier and welded steel mesh with the fiberglass strands. Steel plates are "L" shaped and are several inches into the slab to the rebar.
Should have mentioned it's a Central Wisconsin build. How can I edit the title?
