Greatest Girlfriend in the WORLD!
N
nine4gmc
Dallas
I like old Consew or Phaff but use my old Singer 90% of the time because I learned on it and I'm real used to it's quirks. Juki make a few affordable machines too, you'll want a "walking foot" style in any of those brands and having reverse is great. I can keep an eye out if you'd like but shipping would $uck due to weight.
Strouty
Southern Maine
I will use some of that info for search terms. I need more stuff right now like another hole in my head. I had some older singers that I scrapped a few years back. They were made for specific boots and I could find no one interested in them. They might have worked but I will never know now.
* I am conveying my true thoughts telepathically *
N
nine4gmc
Dallas
Nine, does that row of carry boxes on the high shelf have stuff in them? Lots of covered stowage there!
My bad, I read too fast and thought you meant the ones on the pallet rack. The row of carry boxes on that purling are empty atm, I may find a use for them eventually but for now they are display only. I am trying to phase out the crown top in favor of the older heritage logo so they may be sold off or decoupaged for more decoration. :dunno:
N
nine4gmc
Dallas
I've been chasing ghosts at the shop....and bats...and snakes...and rats(turned out to be baby possum)...and bugs...
Anyway, the outlets behind the fridge and at the center pole between the roll up doors were not usable when we moved in here. Also, none of the outlets were grounded to the metal box, I took the liberty of grounding them myself, hope this is correct? I started at the broken receptacles, changed all the damaged ones, then tested again and still 80v on one leg. I checked the breaker and found the issue, it melted out and was not making contact. Finally got all the outlets working and labeled at the box. The box is not grounded either, should I hammer a ground rod outside and run a ground to it?
Changed the left outlet and added a metal plate.
Changed out the left outlet and right switch to lighted(goes to outside light) and added a 30a 240v grounded 4 wire outlet, there was just wires hanging out where the old 240v was so I put a cover there, then new outlet was too large for that small box.
Then I upcycled some of the free old fence boards I picked up last week from the curb and made a 20' long center divider wall. The bottom will be some sort of metal, like corrugated tin or similar(gotta get with my scrap guy :).
alinc100
Dearborn,MI
Nine ,
The place is looking great. I can only imagine the work that can be done after you get the place set up and can just work when your out there.
Very nice place to spend time working. Keep at it and keep sharing the pics!!
Strouty
Southern Maine
The divider wall looks great, I want to know how you like it long term. I have been considering doing this just to add more wall space for equipment and benches. I was going to go full height to keep sparks and dust from the fabrication area out of the rest of the space. I was worried it would cause me issues with heating the space in the winter.
N
nine4gmc
Dallas
This building is shaded on the cabinet bay, all day but the machine side catches sun in the evening. I plan to go all the way up with the divider, maybe over head cabinets above the wall but definitely will be divided for dust/overspray etc.
I'm diggin' the rustic look on that divider wall:thumbup: I might have to cop that idea for my wife's office. Cheap and stylish!
Yes, I reused the 2x4's from a sheet rock wall I had at my other shop and picked up a pile of old fence boards from the curb in the neighborhood last week. The price was right, FREE! I like the look as well, hope to find some good tin soon and finish it out!
What is this thread really about? I expected to see some devotion to the girlfriends.
My girl bought a house and it came with a big *** shop:dunno:
Strouty
Southern Maine
I like the title. He probably just wanted to see more of the GF. It is shaping up nicely. I got some of my durham slide out draws bolted together today, but that was about all I did. You were much more productive than I was.
:thumbup:
bluebolt
Benton LA
Left bay will be machines, I will move some of the smaller ones like pedestal grinders/sanders welding carts, etc to the center wall once it goes up and then I can bring my lathe over and put it by the man door at the end.
Does that 6x48 belt sander have the correct pedestal upper part? I see a block of wood there. If not you never know who might have one hanging around :thumbup:
N
nine4gmc
Dallas
OK, put me down for that piece too! I rigged up the block of wood until I could find one, should have known you'd have one!
Trey T
Houston, TX
Just saw this thread but felt mislead by your title... WHERE THE PIC OF THE SAID "GREATEST GIRLFIEND"? All I see are your **** tools.
N
nine4gmc
Dallas
Someone had a 4" joiner rigged on top with a wood plate and motor mount. There is a triangle shaped cast metal bracket under the wood. :dunno:
Any chance you have a pole mounted top plate for the Craftsman band saw laying around? I have the band saw on a double pole base from a 6" joiner right now but I'm looking for an original stand for it too.
Alexbn921
East Bay Nor Cal
Nice setup nine. Gonna be following along with your build and organize. Man its a lot of work to move. What are you going to build in your shop? It looks like a lot of space for just home use.
That breaker looks like an old stab lock style. That are known to not trip under load and burn up.:mad: Plus they are expensive compared to newer breakers. It might be worth your time to replace the panel.
YES, on the ground rod.
bluebolt
Benton LA
And the pile grows bigger...
The triangular top piece stand is probably for a shaper like this. http://www.ebay.com/itm/Vintage-Cra...386379401?pt=Routers_Bits&hash=item1c43312889
AND of course I have a genuine complete bandsaw pedestal stand, complete with motor mount. Adding it to your pile!
N
nine4gmc
Dallas
Thanks Alex, I started a thread over in the electrical section inquiring about the panel and ground situations. I do auto upholstery by trade, plus I like to tinker a lot, I've been renting a shop to work from for almost a decade while living in apartments.
Garageman, that top is for the newer style base with angle iron legs, I'm looking for the pole stand like the other machines are on and like Bluebolt has.
Bluebolt, that is exactly the triangle piece that I'm talking about, you are the man!! You are the man again for having a band saw stand, that makes you at least two or three men right now, hold your head high! :lol: I think I may part that table saw out that is on the stand, then rig up a new top for the other 8" to sit on, it's in way better condition. Do you need another table saw or any parts from this one? The table is exactly the same dimensions as the newer 8" but the insert was 1/2" longer on the older saw on the stand. I took the joiner off last night and measured, the joiner will bolt right on the newer table and the table extension is the same size as well, though I don't need another extension or joiner since the newer saw came with both extensions and a separate joiner.
Daedalus
Some pretty cool tools there, but I can tell the shop is not as big as you thought! They never are. You gots some keepers in the garage and a keeper at home.
Years ago my gf and I had been looking for a house to buy together, and had looked at quite a few places. We couldn't afford much, and were checking out an open house in a real dump of a place--original 1940s tiny 2/1 in a shady neighborhood. It was probably the smallest house we had ever visited, but in the back was a 18x38 garage; the largest garage of any house we had visited. Certainly not a home for a woman to get excited over. After walking through it (took about 12 seconds to see it all) I asked my gf what she thought. "I think we should get it" was her reply. She knew I wanted that garage! We put up with that house for 8 years until we could afford something better...and after looking at over 100 places, again bought the 1 with the best garage. Luckily the house that came with it is a little nicer and in a much better neighborhood than the last one. Some women just know the way to a man's heart, and if we're smart, we'll never let 'em go ;).
s10xtremist
State Capitol Raceway, LA
Not the Stitchcraft dude. What are you working on? Check your PM
My neverending project- 2002 S10. I had a power sliding sunroof installed at Tops Unlimited back in '03. They cut out pretty much all but the perimeter of the headliner board to fit the sunroof, then glue headliner fabric to the remaining perimeter and to the edge around the sunroof. The fabric in between is just stretched and kinda floating there. They do this so the 'roof looks like a factory-installed unit. I have a spare and nearly perfect junkyard headliner and I wanna see if I can trim out just the area for the sunroof to eliminate the unsupported part. Figured I could use professional's input. I also have some nearly mint '09 Avenger seats to swap in, but I'd like to get the inserts replaced with something that better matches my truck. They currently have a sort of houndstooth material. I have the covers stripped off already, so it should be just a cut out/trace/sew-in job, I would think. At the moment, the interior isn't the highest on my list. Finishing my shop and getting the V8 swap done is. I got your PM, and your number saved in my phone.
bluebolt
Benton LA
The pile is loaded for early morning leave out and transfer to the rental car (its actually cheaper for me to rent an economy car for four days that gets 35 MPG than the 15 MPG my Excursion gets on the interstate)
Gerstner-Check
9" saw parts-in Gerstner
Vise spindle-in Gerstner
Grinder stand-Check
Sander pedestal top-Check
Complete bandsaw pedestal with motor mount-Check
Mystery shop warming gift-Check!
N
nine4gmc
Dallas
Cool story, sounds like we are both lucky!
I have an idea what you mean on the sunroof, I'd need to see it in person to know how to go about actually fixing the problem though. Hit me up when you get closer to finishing.
Gerstner-Check
Grinder stand-Check
GREAT! Did you want to drop by tomorrow or what day is convenient for you?
bluebolt
Benton LA
I have 3 identical 10" saws, eventual plan is use the best parts to make 2 nice ones and put both on a custom stand with an extension bolted between them and extensions on both sides as well.
Plus I have two heritage 8" saws I am selling.
So no I don't want another saw LOL!
N
nine4gmc
Dallas
Bluebolt showed up with lots of goodies, can't wait to get some more machines mounted on these pedestals and the Gerstner is beyond awesome!!
And I flipped some fishing lures I found on the side of the road for free and turned that cash into tin, literally. Finally got the lower half of my wall up, now just to trim out edges for appearance and build the upper shelves.
Cruster
enjoy it while you can; soon she will kick your *** to the curb for another man because you spent too much time in the shop..:evil:
LOL, just what I was thinking. And, it will ALWAYS be hers. If you don't marry her that is.
Still, pretty sweet.
bulletpruf
San Antonio
Nice shop! Like the wall you put up - class + character + cheap = WIN!
I miss BR; went to LSU back in the day ('93 grad). Best 7 years of my life!
Too bad I moved away; could have sent some business your way with auto upholstery.
Scott
Olinrj
Greenfield, WI
Subscribed! Great shop you've got, and an even better girlfriend. Your work and ingenuity to bring various items together are awesome. Thanks for the inspiration.
rmalkow2
Brighton, MI
That wall looks great. I love the rustic barn look. And functional anywhere you might want to hang something. Shop is looking good.
N
nine4gmc
Dallas
Hey, thanks for stopping in guys! I've been busy the last couple weeks and finally have some update pics. Still a lot of sorting going on and shuffling of cabinets/drawers plus I have to bring my lathe over this week and take the short file cabinets taking it's spot to scrap but it's almost DONE.
Before:
During:
After:
Before:
During:
After:
N
nine4gmc
Dallas
Also made this EXIT sign to match the wall from fence and tin, posted in my projects thread.
Strouty
Southern Maine
The shop is looking great, I love the exit sign! You and I seem to like storage cabinets a lot. I wish my shop were closer, I think I would get more done, driving 30 minutes one way to do a quick project *****.
As lots of people have said to me, you need to go up those walls. How tall is the shop again?
