Could use Expert advice on Snap On Buy
Hi Folks,
I have an opportunity to purchase what appears to be a somewhat older Snap on set in that it still has the old model ratchets (936) etc.. Below are the part numbers.
Just curious if $900.00 is a great deal or just okay. I have not had an opportunity to see the tools yet, but gather they are all in new condition.
Any advice would be appreciated.
Thank you,
Bobby
112TMMSY Set Socket Metric, Semi-Deep, 6-Point (12 pcs.) (5 to 15mm)
1/4"
T936 Ratchet, Sealed Head (High Strength), Standard Handle, 4 7/16"
1/4"
TMXK2 Extension, Knurled,2"
1/4"
TMXK4 Extension, Knurled,4"
1/4"
TMU8B Universal Joint
1/4"
F936 Ratchet Sealed Head (High Strength), Standard Handle, 7 11/32"
3/8"
211FSSY Set Socket Semi-Deep, 6-Point (11 pcs.) (1/4" to 7/8')
3/8"
206EAU Set Adaptor/Extension (6 pcs.)
3/8" (long, medium, short extension, 3/8-1/2 & 3/8-1/4 adaptor
universal)
212FSMY Set Socket Metric, Shallow, 6-Point (12 pcs.) (8 to 19 mm)
3/8"
212FSMSY Set, Socket Metric, Semi-Deep, 6-Point (12 pcs.) (8 to 19 mm)
3/8"
S936 Ratchet Sealed Head (High Strength), Standard Handle, 10 5/16"
1/2"
SXK3 Extension,3
1/2"
SXK5 Extension,5"
1/2"
SN15B Breaker Bar, 15"
1/2"
313TWMYA Set, Socket, Metric, Shallow, 6-Point (13 pcs.) (12 to 24 mm)
1/2"
OEX709B Set, Wrench, Combination, 12-Point (9 pcs. In tray) (3/8" to 7/8")
OEXM710B Set, Wrench,Metric,Combination, 12-Point(10 pcs. In tray)(10-19mm)
AWM110DK Hex Wrench Set
12,10,9,8,7,6,5,4,3,2,1 mm, 1/16, 8 tiny ones, 2 set screws
SDDX8O Set Screwdriver, Combination, Flat Tip/ Phillps, Black (8 pcs.)
Philips #2, #1 #2 stub, flat 3/8, 5/16, 1/4, 7/32. 7/32 stub
SDHP421R,SDHP311R,SDHP221R
SDH8,SDH6,SDH4,SDH2,SDH1
PL300ACP Set Cutters/Pliers, (3 pcs.)
Pliers 47CF, Cutter 87CF, Long Nose 96CF
91ACP Pliers, Adjustable Joint, Interlocking Channel, Industrial Finish, 9-1/4"
PRC36 Pliers, Retaining Ring, Interchangeable Tip, Convertible, 7-3/4"
PWC6 Wire Stripper/Cutter, (AWG 10 to 20),6"
PPCT710A Set Punch and Chisel, (11 pcs.) (CenterlPin/Starter/Flat)
Punch 3/32,5/32,3/16,3/32,5/32,3/16
PPC103A,PPC105A,PPC106A,PPC203A,PPC205A,PPC206A
Punch point 3/16 PPC4A
Chisel 3/8, 1/2, 5/8
PPC812B,PPC816B,PPC820B
Chisel and punch Guage PPC1A
Pouch PPC710BK
HBPT16 16 oz Plastic Tipped Hammer
HBBD16 Ball Peen Hammer 16 oz
HS16A Hacksaw, Deluxe (for 12" blades)
ECF1B Flashlight, Heavy Duty (2 "D" cells)
YASG153 12' Tape
TPMA12
GA295 Mirror, Round, 14" extension (Mirror: 2-1/4" Diameter)
PT5B Pick-up Tool, Magnetic, Telescopic
PT5C
CSA8C Carbon Scraper, Rigid Black, 7/8" Blade Width, 7 5/8"
QD2R100 Torque Wrench, Adj. Click-type, U.S.,
Fixed-Ratchet, 20-100 ft. lb., 3/8" drive
JCK7D Fender Cover
CT4G Circuit Tstr
2003LN Set, Socket, Double Ended Lug Nut (3 pcs.)
1/2" 13/16 <-> 3/4 combo
3/8", 3/8" deep, 13/16 deep (for spark plugs?)
FL936 Ratchet Sealed Head (High Strength), Long Handle, 10-5/16"
FTXB27E Socket Driver, TORX, Heavy-Duty Removal, T27
FTXB45E Socket Driver, TORX, Heavy-Duty Removal, T45
FTXB50E Socket Driver, TORX, Heavy-Duty Removal, T50
FTXB55E Socket Driver, TORX, Heavy- Duty Removal, T55
BT11 Tool, Brake Spring, for Bendix
B1356E Tool, Brake Retainer Spring
KRW183 Box" Metal, 3 Drawers, Removable Tote Tray,
20 19/32" x8 1/2" x 12"
BJ42LX
WNY
Crossfire,
Most of these collections that come up for sale say, "too much to list", so you're way ahead of the game knowing what is in the lot.
Make a spreadsheet will all the part numbers and the current list prices. You can check on eBay, but most used Snap on in good condition goes for 40-50% of list. New on eBay goes for 50-70% of list.
You can adjust from those numbers based on old style ratchets/wrenches and overall condition of the tools.
Then you have to decide what you'll keep and what you'll resell. How much of a hassle is it to resell and how much is that hassle worth to you?
Strouty
Southern Maine
Just a quick look shows 5 complete socket sets and two sets of wrenches. If you were to say $100 each for those (and if these are new condition that would be great prices), that is $700 right there. I see more than $200 left in that list. Sell what you don't need or want and you could be sitting pretty.
C
Thanks Folks, I really appreciate the help! I just went to take a peak and may have hit it pretty good the tools are new and unused. I will report back if I end up getting the set!
Bobby
Richard Cranium
central Washington
make him an offer, most people sell stuff that high, has some wiggle room in their price, You could save your self a couple of hundred dollars maybe. It is worth a try. Rich
Strouty
Southern Maine
Bobby
Awesome, then the price is a great deal.
No Sir, not from Dan in NH
I ran across him and saw you were close enough for it to be possible. He was great and had a ton of NOS from his previous life as a dealer.
C
Crossfire,
Great info here thank you. I did end up making the buy and was able to negotiate as well, so I am a happy camper. Not only that, but the ratchets were actually new, not the older models but the F80, SL80 etc...not one single tool was used!
jml93
Brookville, OH
As said above, I would buy these tools in a heartbeat. Then you can keep what you want and sell the rest on eBay. You may even be able to trade them in against other Snap-On tools with your dealer. I do this quite frequently with no trouble.
SASORacing
Utah
Yes good deal, buying brand new $900 would vanish into a puff of smoke after a few sets are added to the cart! Bonus is some of that is new.
C
I haven't had time to organize anything yet, so these pics certainly don't do the set any justice, but I hope you guys get the idea.
[/IMG]
