Crossfire Arms LLC
- Joined
- Apr 24, 2011
- Messages
- 24
Hi Folks,
I have an opportunity to purchase what appears to be a somewhat older Snap on set in that it still has the old model ratchets (936) etc.. Below are the part numbers.
Just curious if $900.00 is a great deal or just okay. I have not had an opportunity to see the tools yet, but gather they are all in new condition.
Any advice would be appreciated.
Thank you,
Bobby
112TMMSY Set Socket Metric, Semi-Deep, 6-Point (12 pcs.) (5 to 15mm)
1/4"
T936 Ratchet, Sealed Head (High Strength), Standard Handle, 4 7/16"
1/4"
TMXK2 Extension, Knurled,2"
1/4"
TMXK4 Extension, Knurled,4"
1/4"
TMU8B Universal Joint
1/4"
F936 Ratchet Sealed Head (High Strength), Standard Handle, 7 11/32"
3/8"
211FSSY Set Socket Semi-Deep, 6-Point (11 pcs.) (1/4" to 7/8')
3/8"
206EAU Set Adaptor/Extension (6 pcs.)
3/8" (long, medium, short extension, 3/8-1/2 & 3/8-1/4 adaptor
universal)
212FSMY Set Socket Metric, Shallow, 6-Point (12 pcs.) (8 to 19 mm)
3/8"
212FSMSY Set, Socket Metric, Semi-Deep, 6-Point (12 pcs.) (8 to 19 mm)
3/8"
S936 Ratchet Sealed Head (High Strength), Standard Handle, 10 5/16"
1/2"
SXK3 Extension,3
1/2"
SXK5 Extension,5"
1/2"
SN15B Breaker Bar, 15"
1/2"
313TWMYA Set, Socket, Metric, Shallow, 6-Point (13 pcs.) (12 to 24 mm)
1/2"
OEX709B Set, Wrench, Combination, 12-Point (9 pcs. In tray) (3/8" to 7/8")
OEXM710B Set, Wrench,Metric,Combination, 12-Point(10 pcs. In tray)(10-19mm)
AWM110DK Hex Wrench Set
12,10,9,8,7,6,5,4,3,2,1 mm, 1/16, 8 tiny ones, 2 set screws
SDDX8O Set Screwdriver, Combination, Flat Tip/ Phillps, Black (8 pcs.)
Philips #2, #1 #2 stub, flat 3/8, 5/16, 1/4, 7/32. 7/32 stub
SDHP421R,SDHP311R,SDHP221R
SDH8,SDH6,SDH4,SDH2,SDH1
PL300ACP Set Cutters/Pliers, (3 pcs.)
Pliers 47CF, Cutter 87CF, Long Nose 96CF
91ACP Pliers, Adjustable Joint, Interlocking Channel, Industrial Finish, 9-1/4"
PRC36 Pliers, Retaining Ring, Interchangeable Tip, Convertible, 7-3/4"
PWC6 Wire Stripper/Cutter, (AWG 10 to 20),6"
PPCT710A Set Punch and Chisel, (11 pcs.) (CenterlPin/Starter/Flat)
Punch 3/32,5/32,3/16,3/32,5/32,3/16
PPC103A,PPC105A,PPC106A,PPC203A,PPC205A,PPC206A
Punch point 3/16 PPC4A
Chisel 3/8, 1/2, 5/8
PPC812B,PPC816B,PPC820B
Chisel and punch Guage PPC1A
Pouch PPC710BK
HBPT16 16 oz Plastic Tipped Hammer
HBBD16 Ball Peen Hammer 16 oz
HS16A Hacksaw, Deluxe (for 12" blades)
ECF1B Flashlight, Heavy Duty (2 "D" cells)
YASG153 12' Tape
TPMA12
GA295 Mirror, Round, 14" extension (Mirror: 2-1/4" Diameter)
PT5B Pick-up Tool, Magnetic, Telescopic
PT5C
CSA8C Carbon Scraper, Rigid Black, 7/8" Blade Width, 7 5/8"
QD2R100 Torque Wrench, Adj. Click-type, U.S.,
Fixed-Ratchet, 20-100 ft. lb., 3/8" drive
JCK7D Fender Cover
CT4G Circuit Tstr
2003LN Set, Socket, Double Ended Lug Nut (3 pcs.)
1/2" 13/16 <-> 3/4 combo
3/8", 3/8" deep, 13/16 deep (for spark plugs?)
FL936 Ratchet Sealed Head (High Strength), Long Handle, 10-5/16"
FTXB27E Socket Driver, TORX, Heavy-Duty Removal, T27
FTXB45E Socket Driver, TORX, Heavy-Duty Removal, T45
FTXB50E Socket Driver, TORX, Heavy-Duty Removal, T50
FTXB55E Socket Driver, TORX, Heavy- Duty Removal, T55
BT11 Tool, Brake Spring, for Bendix
B1356E Tool, Brake Retainer Spring
KRW183 Box" Metal, 3 Drawers, Removable Tote Tray,
20 19/32" x8 1/2" x 12"
Thank you,
Bobby
1/4"
1/4"
1/4"
1/4"
1/4"
3/8"
3/8"
universal)
3/8"
3/8"
1/2"
SXK3 Extension,3
1/2"
SXK5 Extension,5"
1/2"
1/2"
1/2"
Pouch PPC710BK
YASG153 12' Tape
TPMA12
PT5C
JCK7D Fender Cover
CT4G Circuit Tstr
