De-Buring Wheel- You need this.
lauver
Belton, TX
$70 for a 6" wheel seems kinda pricy...
Am I the only one who thinks so?
I have never bought one before so I know nothing about DB wheels.
383 240z
Findley Twp. Allegheny Co.
I've got one on the little grinder at work. Love that thing! Yea they are a little pricey but at $90 an hour shop rate, it's cheap compared to handing a guy a file. Keith
scratchedup
Fayetteville, GA
At some point what is your time worth.....
Before I buy an expensive tool I wait and research for years to make sure its going to help me and save time.
I mounted this on a cheapie bench grinder...it was cheap and a mistake.
Cheap tools are IMO are always a bad idea.
tarbellb
Oregon
Whats the difference? Is it a softer, malleable material?
Like a spinning Scotchbrite pad?
Fcvapor05
That's exactly what it is. Dense scotch brite on a mandrel. They are available in multiple levels just like scotch brite.
scratchedup
Fayetteville, GA
I actually have this same question. My purchase was based on a friend of mine who is a picky machinist.
IMO its less abrasive then Scotch Bright.
What I do know is it was well worth it and it saves lots of time.
Voi
Western South Dakota
Can you tell what "level" one is by the color like you can with the pads?
I picked up a couple of these at a garage sale recently. That's a 1/4" shaft and the pic shows the color accurately. What types of situation would these be good for?
Also, what sort of tool at these typically used on? I assumed a die grinder but on the back it says do not exceed 3500 rpm. I assume die grinders are much faster than that.
rlitman
Long Island
That's not the same thing. What you have is made to go on a drill and strip paint.
Fcvapor05
ShawnT
Plano, TX
I have been using these for several years and they have been one of the best additions I've made. Sometimes it's the little things.
organ
Atlanta
Nope. Only reason I haven't bought one... I hear they last quite a while, but still...
Exceller8
Banning, CA
I would be totally lost without my scotchbrite wheels. I have a soft (well worn) one that I use to clean up tools. I have a harder wheel that I use for removing material that a standard grinding wheel might be too harsh for.
Another thing that the scotchbrite wheels do really well is put a polished edge on a piece of cut steel. I haven't found anything yet that does a better job. :thumbup:
