Fretters
Have to belt sand it down a little and It will be perfect
Get the files on it.
I can't believe I took the time to rebuild one of these vices but I did. It was easier to take it apart to paint it than it was to do it while it was assembled. It's my "back yard" vice, the good ones stay indoors.
I've never seen one that is all in pieces posted in this thread so I thought you guys would "enjoy" it.
View media item 42797
View media item 42798
All paint and hardware purchased at Canadian Tire eh.Oil can filled with concrete and hockey puck skates? Only in Canadeh lol
I have removed the both the set screw and the pivot bolt and have penetrating oil seeping out between the two pieces however it will not budge. I can see the joint is free as the upper plate or jaw will flex apart from the body but still no dice. Does your vise have a bolt or pin in the side where it looks like there is a pin or broken screw in mine?
That ugly pin sticking out is a taper pin for square alignment for regular use. That needs to come out, and its often a bear ( hence the vise grip teeth marks on the head of the taper...)
Joe very nice Parker, does it hav a swivel base? Are you going to restore it. Gonna have to start wearing steel toes shoes with the heavy iron you are picking up.
Fretters, you been drinking? Ive got to remove 2-3 mm of material the entire top half of the back of that GIANT slide. The hand held belt sander will remedy it well and quickly.![]()
*****.(Mind you, that might explain why I have Popeye like arms
Oh yeah, swiveler baby, nice and smooth. I will need a Parker swivel bolt though, 1/2", as it it restrained simply by a 1/2 bolt right now.
I told my wife that this is the first vise that concerns me. I keep forgetting how big it is. I'll tell you, moving it was a b because I couldn't separate the dynamic jaw.
I am planning to paint it Hammerite green, on the lines of the old Wilton Green.
I'll post more pics soon.
Just send me the prentiss, I'll fix it up for you... and maybe return it in a decade or so...![]()
This is probably the least used and most pristine old school bullet I've ever come across..
I just finished my first vise, Started with four Columbian's and wrapped this 604-1/2 M up tonight. I have much to learn, the easiest job on these vises is making all the hardware. I sure respect all you vise re-finishers. The Columbians are pretty nice for a light duty vise, if I wanted one of these for my own I would add a thrust needle bearings backed up by the set screwed bushing on the spindle, and tighten up the play like I did on this one by adding a thicker Copper Aluminum thrust washer. The play on this vise is very minimal, maybe 20 degrees. Well first one down 68 more to go.
Hi there! I found this beauty on my Saturday garage sale jaunt a couple weeks ago, in a barn near Lunenburg, NS.
Happily, it fit... no second trip ... and under the max weight for the engine deck lid. And it's in use already, restoration in the winter.
Anyone have some NOS pipe jaws for a Record 634?........nope?
Off to Wanted.......
Cheers
Thrumcap
Outlaw is correct, I had experience pulling one of these Wilton pins that was really stuck. ended up drilling a relief hole before it finally was free. My first go around was welding a slide hammer on to the pin with my TIG. Even with this big chunk of brass slamming it, it still did not budge. I then drilled out a relief hole around a 1/2" and it came out. I measured Macklins 4" pin and came up with 2-1/2 degrees total or 1-1/4 degrees per side. His pin was .692 at the top and 1-1/8 length of taper. For Macklin it was safe to drill with a 9/16 drill bit. The taper figures out to be .100 smaller roughly. Lets hope you can get the pin out without drilling it or you will have to fab on. Good luck.
Fetters is probably staring daggers at you right now from across the pond.![]()
Well since I don't have access to a lathe to make another one.... I am grasping at straws to get this one out without too much further damage, pretty sure with some time and elbow grease I can fix the sin I already committed against it. I was thinking of baking it in the oven and then applying liquid nitrogen to the pin..... What do you think?
There is a chance that will work, you will have to make a funnel or something to capture the L Nitrogen, you know how that stuff bounces around when pouring. Here is my drawing that is in complete but it might be close to your pin just in case.
