do either of these exist?
jim1987
Doing a job the other day two tool thoughts came to mind that would have helped.
1. A shorter 3/8 speed. My kobalt on was about 4" too much in the way.
2. Ratcheting 3/8 spinner handle. I suppose I could use a 3/8 drill bit gismo to put in my ratcheting screw driver but would rather have a one piece unit.
So does anybody sell these tools?
How about a 3/8 to 3/8 ratchet adapter? I have an old Mac 3/8 spinner handle.
Thanks
RECox286
South Joisey (yeah, that is part of the USA)
Perhaps a 1/4" speeder with an adapter would be in order.
I have a SO ratchet adaper that I can use with a breaker
bar or speeder, if that answer fills the bill. Refer to SO's
online catalog. I'm sure other tool providers have similar
items.
Uncle Bob
J
jim1987
I have a 1/4 speeder. Seems it would have been to long as well.
For the job needed im now thinking of a 1/4 ratchet adapter, and a 12 point 13mm swivel socket.
KnurledNut
n/a
Would this have worked?
Ameriman
The 3/8 ratchet spinner was made by Proto in both 3/8 and 1/2 drive. I thought about getting them off ebay as they show up, but them seem to be in OLD condition. I don't think anyone makes them today. I only knew that Craftsman and Proto used to make them.
J
jim1987
I think I found my solution. Total spent $10~
$3 chinese hdx ratcheting t handle
$6 12 point kobalt swivel socket
Then use a hex to 1/4 adapter, then a 1/4 to 3/8 adapter, a 1" 3/8 extention then the swivel socket.
Ill probably end up taking the short extension out as the hex shaft extends 3-4" out of the t handle.
J
jim1987
Actually it doesn't lol. There's a hex shaft that inserts into the t-handle. The hex shaft locks into place via the black collar on the t handle. Then that hex shaft has the bit holder on the end, thats where the magnet is.
