New Member Hello- Welding Table
jonemark401
I have been a fan of this site for a long time for the great ideas I've gotten over the last couple of years. I just really enjoy seeing how other folks do stuff and this site has been a lot of fun to poach ideas from. I will start with my workbench/welding table hybrid. Wanted something strong, durable, but also mobile. Got these casters several years ago and thought they'd be great for a gantry or welding table :thumbup:. This table is made with a 3' x 6' top, 1 and 5/8th thick top. The legs are 4" 0.250 wall and the cross braces are 2" 0.188 wall. The top plate weighs 1,200 lbs. All in all I think the table weighs 1,600 to 1,700 lbs- casters are 60 lbs each. Hauled the plate home in the back of my m101A3 trailer and welded the table upside down. I flipped it by winching it out of the trailer onto my other table just long enough to lift it up, get the smaller table out from under it, and lower it onto blocks- all using an engine hoist and bridge clamps. Did all this without getting too close to it as a safety margin though the clamps were up to the task and the hoist lifted it with ease. I'm really pleased with the way it turned out. The casters are rated 5k each and at 12 inches diameter roll nicely. The table stays put by locking out the wheels at 90 degrees to each other though most times I don't even have to do that. I wanted a general purpose table that would double as a good welding table and so far it fills the need quite well. I spent a lot of time getting ideas from others experiences. The table in the background was my first attempt and it is 2.5' x 4' with a 5/8th top. I was able to get both tables to within a mm of each other in height if I need expanded working surface.
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
DIC
That's one hell of a table. Need to put a date on it ... Its gonna be around a long time
PanelDeland
Now you don't need a set of wheel dollies, just put the car on that table and you can roll it around.
Nice table and I'll bet it lasts into the next century.
pepi
Woodstock, GA
Sacrifice a couple of feeler gauges, or get some plastic feeler garage strips, shim the low table will fix that.
Like that table btw
Styx
Fraser Valley, BC. Canada
Holy overkill... what the heck are you building that you need a table like that???... Don't get me wrong that is a thing of beauty but WOW!!!:beer:
J
jonemark401
The date for the steel is printed on the lower crossbar- 6-12-14. Hopefully it'll stick around for a while.
J
jonemark401
I wanted to really be able to clamp things to the table and have them hold true while I weld them. Was looking at 1" thick but the 1 5/8 plate became available so I used it. I do go for overkill sometimes. Nice to know a few things in my garage will give a lifetime of good service and then some. Some of my most treasured possessions are my Dad's tools I used to use when I was a kid.
Jackfre
N CA
Very cool! What kind of drive train and motor are you going to put on it?:thumbup:
WhoWhatNow
Collegeville, PA
Now get a mag drill and drill and tap holes every 3". I just did my small welding table and set up is like night and day.
Great table btw.
A_Pmech
IL
Jone, you did a very nice job with that. That's the way a plate welding table should be built. :)
jameson
Man, weld your name and date on the bottom of the plate. That table is stout enough to last a century or two.
