Guess this socket.......
Jokeman
Boston
Here you go, its a specialty socket. Good luck:wtf: Socket next to it is a 3/8ths drive 15mm craftsman deep socket.
engineboy
NV
I cant remember the exact application, but its an axle nut socket.
Uncle Buck
Kansas
Man, with no size relationship whatsover to go on it makes guessing the application that much more difficult. As an example going from that pic I cannot tell how deep the socket is, nor can I truly get a clue as to the OD of the socket, the only thing to compare with is the driver hole in the center of the socket, meaning that unless you have encountered the fastener in question you are pissin up a rope!
I am going to guess that the socket is used for securing the radio antenea mast nut to the top of the fender on older cars.
TAMPAGT07
Palm Harbor, Fl
Daaaah...It's obviously a Craftsman deep socket (Metric). It's right there laying on a piece of plastic paper, next to a dickfer...:lol_hitti
-B-
Northshore of Boston
Not enough lobes for any of my applications, it must be the finnegan pin retaining nut drive tool.
Not enough lobes on it for high torque applications may be some dust cap retention nut of some sort.
J
Jokeman
Boston
One more hint. Its a 1/2 inch drive socket. I'll give it one more day then I will let you guys know what its for. I had never seen anything like it before until I needed it.
J
Jokeman
Boston
Socket it to remove the retaining nut for the disk brake on 2005-2006 Arctic Cat snowmobiles with a diamond drive setup.
rsanter
visalia ca
it is an installation and un-install tool for a non-hexagonal internally threaded fastening device intended for use in freezing or non-summer overland travel equipment
bob
qdvuu
Norcal
Interesting, i thought it was a socket to remove the fill cap for US domestic market cars' headlight fluid.
Funny thing is, I actually had a car that had headlight fluid! I had an '86 Isuzu Trooper that developed a gap between the face and body of the headlight assembly so it would accumulate water in wet weather. I drilled a couple of drain holes in the bottom. Problem solved.
Btw, I replaced the Isuzu name badge on the grille with a swank Cadillac one that I picked up at a junkyard. Now this was in the late '90s, before Cadillac had SUVs, and people were giving me comments on my nice ride.
