The VISES of Garage Journal
EOC_Jason
Bentonville, AR
The Revised/Revision vises I've seen actually have the "R" as part of the model number and have an "oil" hole in the dynamic jaw. What I find interesting about Davefr's vise is that it has neither. I was thinking that the R on Davefr's vise may have been from an era or a short period when Reed cast and R for "Reed" into the dynamic jaw.
I wasn't talking about the swivel jaw. Someone posted asking about their 208R.
That swivel jaw is obviously an older model. My guess the R on the dynamic stands for Reed too...
EOC_Jason
Bentonville, AR
So I was taking apart the Reed 208 tonight to let it soak and it came apart in about 2 mins so easy until I reached the large flat head type bolt on the bottom... I tried every screwdriver and crowbar and even took another threads advice about making your own out of scrap metal and vise grips... but nothing worked... Going to the oil soak in tonight and try tomorrow... Anyone found a better tool for the job? Thanks!
I took a large nut and welded a piece of angle to it that I found fit the slot. Then I use my air impact to get them loose (sometimes)...
Does the base swivel? If not, then that pin is probably seized good. You can secure the base down then "spin" the static housing off. Then get a mini-sledge and beat the pin out of the base. That's what I had to do on one of mine that was rusted like a SOB...
If it does swivel then it's the threads that are gummed up. I would just spray the penetrating oil in there. If you soak around the base where the main nut is inside, it will hopefully work its way to the hole underneath where the thread is for that swivel bolt. Then make up a little piece like I said initially and try going loose / tight with an impact back & forth and it will hopefully come free.
exmaxima1
Midwest
Ex: I own a patent pending Wilton bullet with a 10/46 stamp on it which tells me that it was an October 1941 vise then Pearl Harbor was about a month later so I bet a lot of factory workers left their jobs to enlist.
That is consistent with what has been conveyed over the years---and the fact that it is a Pat Pend model pretty much CONFIRMS the 1941 date. If yours was a No. 4 (or an 840), it would be unlikely as the patent was not approved yet in 1941. Such as this example:
http://www.ebay.com/itm/like/261580862675?lpid=82
But it just ruined the notion of mine being Sample #10 of 46 !!! Arrrggghh.
Fretters
South Yorkshire, England
Fretters: sounding like a win, win with the boiled linseed oil before applying paint or mixing it in it. I'll try it on a few of mine before I spray paint to see if similar results. Thanks for experimenting with that.
Seems to be, at the moment. I'll take some photo's of the bits which have been painted with it later. If you try it, I'd try just the one piece to start with and gauge how the paint you're using behaves with it. I may just have dropped on lucky with the paint type I'm using. I use 14 Line poly. synthetic enamel.
oldldh
Fairhope, AL
I know some of you are Chas. Parker fans, so here's a strange one, at least to me...:headscrat
A Chas. Parker 870...
Now we've had asymmetrical jaws before, but this is the first symmetrical jaw, non-symmetrical screw, I've seen...:wtf:
This strange 3 1/2", 40 pound thing is on Ebay...
It's an "On-the-side" screwer...:evil:
I had trouble with a similar similar slotted bolt head on the bottom of a Craftsman vise (not a rebadged Reed). Instead of trying to turn it by the slot, I ended up turning it by grabbing the outside of the head with common vise grips (no pun intended).
Would a drag link socket and impact wrench work?
THIS ^^^ (Hammer impact, not an Air gun...)
and using a good penitrant (Kroil. 50/50 acetone and ATF...)
oldldh
Fairhope, AL
Another Ebay find...
No-reserve auction...
An itsy-bitsy swivel jaw Prentiss...
GETRIDAONE
Auburn, GA
I saw those this morning while browsing
The starting bid on that Parker will scare most people off.
The little Prentiss has some bidders already and probably a bunch more before it ends.
Sam.A
I'm looking for a Parkinson's Ball Base Vise. They were made in England and not so plentiful here in the USA. If anyone has one I'd like to buy it.
Davefr
OR
Thanks for all the suggestions. That "son of a *****" pin finally came out.
I soaked it in Kroil overnight and then put the vise in the freezer for a couple hours. I pulled it out and hit the area surrounding the pin with a MAPP gas torch hoping the swivel jaw would heat up (and expand) more then the pin.
I was able to use a long drift thru the swivel base bolt hole and after a couple hundred taps it finally broke free. I was very paranoid about the cast iron but it survived unscathed.
I'm curious if that pin is a std taper (Morse) or something proprietary for Reed?
Fretters
They're like hens teeth over here too. I've seen a grand total of one for sale within memory, and that one was just too far away with no postage option to be feasible, for me. They're up there with the 5198's on availability.
jakemac
New England
What kind of Reed is this? Guy wants $70 for it???
The best kind ............. COMPLETE !
The picture is hard to read, but it looks to have 3 patent dates on it. I'm guessing they're the 1908, 1912, 1914 dates. It looks similar to the one I have. It's hard to tell the size from just one picture, but I think it's at least a 4" vise.
It doesn't have the oil holes, so I'd say it's one of the early ones. 20's, 30's ???????
If there aren't any cracks, chips, or other damage. And if the screw isn't bound up, then $70 wouldn't be out of the question (but haggle a bit to see if it will go for less).
TreePointer
PA
D'oh! I think I got lost reading the various forum posts. Either that or my grammar school report cards were right--something about needing to pay attention in class. :D
Sam.A
Thanks Fretters. I'll keep beating the bushes and maybe I'll find one.
This probably doesn't fit in with the other vises in this thread. It's an antique engraving vise. Photo by me :)
va.grouseman
Southern-Central VA.
Previously posted by Sam.A
Sam,---There is a Parkinson's Ball Based Vise, posted by demographic on---page 632,---post #7239, with a darn good history lesson right below it.--
demographic hails from across the pond, so he might could direct you.
Also there is a very odd Ball Based Vise posted by Janbuick, on---page 638,---post #12746, and post #12757.---He's also across the pond.
Fretters
Fingers crossed for you on finding one Sam. :) Be sure to post some photo's of it if you get one. Ball vices have never been something which interest me as such, but the Parkinson one just has that beefiness about it which you rarely see with the type, plus Parkinson are my preferred make of vice, so that one has been on my wishlist for a good while. With the Parkinsons though, you tend to find that the 7 and 8's are fairly common, with the 6's appearing occasionally, but any models other than those seem to be once in a blue moon affairs. I'd love to have the full range of Parkinsons, but I'll probably never live long enough to achieve it, judging by the frequency which some of them appear for sale. :D
Links to those posts VA mentioned:
http://www.garagejournal.com/forum/showpost.php?p=2869982&postcount=7239
http://www.garagejournal.com/forum/showpost.php?p=3704256&postcount=12746
http://www.garagejournal.com/forum/showpost.php?p=3705182&postcount=12757
jakemac
New England
If any of you fine gentlemen still wear ties, this may be of interest to you - a tie tac.
Blue
I don't wear ties (except for weddings and funerals), but when there were no bids with 1 hour left on the auction, I just couldn't leave it there. So, now I own a new vise (-like object). :lol:
I was surprised by how heavy it is. While the tie tac is a 3D releif, it was made so that it could stand up on it's own on the base. The handle also spins like a propeller.
This forum is soooooooooo bad for my wallet. :lol_hitti
jpickar
I almost bought that!!!!
Glad you got it.:beer:
John
Sam.A
Thanks for the links Fretters and va.grouseman :)
I sent demographic a PM yesterday and I'm hoping he'll sell me his vise. I will use it for hand engraving. :::fingers crossed:::
Jake, now you have to buy the vise on the tie tac... :evil:
And I was waiting for it to get no bids, and be posted at a lower price... :lol:
jakemac
New England
1 - I'm convincing myself that my 506.51871 is close enough. (fingers crossed that it works) :fingersx:
2 - Obviously, your OCD isn't as strong as mine. :lol_hitti
Davefr
OR
Does anyone know the original factory color of early Reed vises. I've read either black or dark blue. Can anyone confirm this?
drivesitfar
All: correction on the Wilton vise history remark. i meant to say KC-Steve has the Junk yard website with the Wilton history and not Steve-O. sorry.
Sam: i understand you wanting Parkinson vise like you want and who wouldn't.Just wondering if a Wilton baby bullet with the power arm and the clip might be another option. or are they as rare if you are in the UK as Parkinsons are over here?
i'm not planning on selling my Wilton Baby Bullet anytime soon, but here's a picture of how it moves in case you didn't already know.
Jake: nice tie clip.
BFBOB
[Quote
Thanks for the info and reply, I would love to find a small table mount vise (under 3") with the spindle threads enclosed under the slide. Been having a hard time finding one.[/QUOTE]
Search for "1885 vise" and you'll find a really neat series of round-slide, small, clamp-on, covered-screw vises. They come in at least five sizes, 1" to 2 1/2", and I have all five, as does Outlawmws and probably others. The 1885 is the patent date, by George Colton. I might have a spare, and Outlaw probably has dozens. Check that auction site too.
drivesitfar
Jake: are you singing or are you saying Los Angelos (LA) because that is maybe close to where BC lives with all those Craftsmans?:lol_hitti
Fretters: thanks and it's always hard to tell when new members (or old) don't put a location under their avitar. :thumbup:
J HAV
Houston, TX
Found this on front porch a while ago. Never had one with the swivel base before... I think I might keep it. WAS planning on cleaning it up and selling it... We'll see :)
BFBOB
So today I finihed my Parker 825. What a beast, weighing in at 130 lbs with 5" jaws.
The repair on the dynamic tail came out great and it operates smoothly.
Took a while to pick the color before choosing this satin green.
Very nice color. What brand/color name is it?
72CZ
League City TX
Threw my back out moving it so I could take these picks.
Looks Great Joe !!!
