just pulled the trigger on this:
Lbcwanabe
just pulled the trigger on a Bosch 1033vsr and lboxx. I was looking for a good high powered corded drill that would be good for drilling pocket holes. Plus its made in Switzerland. I'll post pics when it comes.
Youngguns
Mtns of Western Maryland
My Bosch corded drill (made in Switzerland) is the most amazing drill I've ever held in my hand. It's probably the most amazing tool I've held in my hand. Mine is a little older than yours, but if yours has any similarity, it'll be the best thing you ever use.
L
Lbcwanabe
No. I was debating between this and the. 3/8 chuck version. I figured better to have more than not enough when it comes to only $30
theoldwizard1
SE MI
IMHO, any hand held corded 1/2" drill that does NOT have triple gear reduction is a waste pf money. Just not enough torque.
For that matter, I think cordless 1/2" drill are a waste also. Same issue. Not enough torque.
Beemer533
Syracuse, NY
I would disagree for all but the largest hole hawg style bits, but corded definitely wins the "staying power" contest.
GarageWarrior
Westerly, RI
Was using this 1/2" D-handle drill for 2 years to power-drive a hoist on a manual pallet lift:
http://www.harborfreight.com/12-in-variable-speed-reversible-heavy-duty-d-handle-drill-69453.html
Plenty of torque to run 1 5/8" nut driver - had to hang on to the side-handle to keep it under control. And people say hf drills are guttless :rolleyes2
purplezr2
Central MN
I disagree, blowing holes in aluminum is what easier with a cordless drill, and I have used a 1/2 bit no problem.
theoldwizard1
SE MI
Ever have to drill a 1/2" hole for a hitch on a pickup truck frame ?
The neighbors was trying to do that using some kind of "D handle" drill. The bit wasn't real good, but he could stall out the motor when he put his weight on it.
I gave him my old Craftsman Professional triple gear reduction drill. It is about the size of your average 3/8" corded drill. When the bit snagged, it spun him around like a rag doll (young guy, about 30, over 200 lbs) and about broke his wrist !
theoldwizard1
SE MI
If you are more than just a casual DIYer, you need 2 drills.
  • 3/8" cordless, even a wimpy 12V one. You will use this about 60-75% of the time.
  • 1/2" corded with triple gear reduction. Use it when you need it. Like whipping drywall mud.
littletoes
NE Washington
I've got that same Bosch in 400 rpm....it will twist your wrist off.
Also, I take it you have never used a HILTI cordless drill, it will also twist your wrist off too, 1/2" drive.
bigfunwmu
S. MN
Last time I had to zip a quick 1/2 inch hole in a heavy double frame readymix Mack, I used a cordless 18v Dewalt drill with a 1/2 inch chuck, a nice sharp 5/16 bit, and a little lube. Finished it with a 1/2 fast twist reamer. No drama, no broken bones, no broken tools.
You don't need a triple reduction gearbox in a drill to get the job done, and 1/2 inch chucks on cordless drills are a no-brainer. Why would you get smaller and handicap yourself? My m12 fuel drill has a 1/2 inch chuck. If it didnt, 3/4 of what I use it for wouldn't fit.
truckdriver
Miami,OK
Last time I had to drill 4 holes on my truck frame I did the same thing. Drilled the holes to 3/8 with my M12 drill and finished with the reamer. Much better than using 5/8 S&D bit.
creativecars
Indiana- where horse and buggies still roam
Worked with an old machinist, he'd say "Get off that damn thing, it's a drill not a press, let it work?"
theoldwizard1
SE MI
Buy bits turned down to 3/8" !
How long do you think you could mix a 5 gallon bucket of drywall compound for ? Haw many 1½" holes could you cut in a 2x4 bottom plate ?
The combination of a lightweight 3/8" cordless and a heavy duty 1/2" corded drill works for me ! (My son borrowed my drill for make some 7/8" holes in some 6x6 with a S&D bit. His cordless just did not have the torque.)
theoldwizard1
SE MI
A good quality, sharp drill ALWAYS is best ! Starting small and using a reamer is also a good suggestion !!
Bigplum
Cotswolds England
blue bosch good , green bosch bad ,
that saying, my old green bosch hammer is still going after 29 years although its semi retired after I bought into SDS
bigfunwmu
S. MN
No need to pay more for oddball bits with a larger chuck.
I haven't ever mixed a bucket of mud or bored any 2x4s with my m12 and I never will. It isn't for that, and never do we ever do that at work in a hydraulics shop.
Glad your setup works for you, it isn't necessarily right for everybody.
L
Lbcwanabe
A quick update. The drill came today with a defect on the chuck. It was completely corroded and almost looked like it was peeling. I have seen similar looking oxidization on boat motors that weren't flushed well after salt water. I returned it to the orange store and got a m18 fuel.
dr_clyde
Holland, MI
To say that a 1/2" chuck on a cordless drill is a waste is completley rediculous.
Today's cordless drills are more capable and powerful than most can handle. Just about every useful tool I use a drill for has a 1/2" shank. Not to mention the industrial supply seldom carries the 3/8" reduced shank stuff.
Just 2 days ago I cut a hole in a stainless tank with a 4" hole saw. Used a cordless makita.
My corded hole shooter only gets used when he job is repetitive AND demanding. Definitely the right choice for mixing lots of mud, multiple holesaw holes, large forstner bits and that kind of stuff. But to say that a 1/2" cordless is a waste is just not true.
nicksnothereman
In the Mojave
Meaning?
:headscrat
Just asking. I know the watch thing but I don't recall ever hearing about them being experts with heavy(ier) machinery. I know they make fancy toothbrushes for colgate though.:D
theoldwizard1
SE MI
Most 1/2" drills, including cordless, spin too fast for "non-professionals". Or maybe I should say it is "too easy" to over speed the bit. Triple gear reduction limits the top speed to typically less than 800 RPM and gives a lot more torque.
Bigplum
Cotswolds England
Meaning?
:headscrat
Elu tools ( the grey ones) were made in Switzerland before it got turned into dewalt , apart from the colour change they were the same
dr_clyde
Holland, MI
My makita drills have a 2 speed gearbox. Low gear has a high rpm of 400. Which is slower than a corded drill.
