IT_Architect
- Joined
- Sep 8, 2014
- Messages
- 41
I tore off all of the wood siding, and replaced the sheeting on the bottom 2' of a 22' deep by 20' wide garage. Now it's time to reside the garage in vinyl. The siding is Certainteed Monogram double-4. The garage has a gabled roof and the sides are 7' high. The front doesn't need to be done because it is brick. The back wall is flat wall with no windows. The starter strips all measure the same distance down from the soffit. The first row of siding lines up all the way around. Then we snapped lines 8" apart to fall in the nailing hem. The sides worked out fine. On the back wall we cannot follow the lines and by the top of the wall we end up 3/4" low. We tore it all off and checked everything. We ended up with the same result. This is unbelievable!
If you know what the problem is, I'd love to hear it.
