What in thee f**k!?
BMcC
Colorado
It's like he found a pile of parts and reassembled it without having ever looked at a drill press.
MikeF2316
Thornhill, ON
Maybe you bolt or clamp your work piece to the table, loosen the table clamp and let the weight of the table force the drill through. :dunno:
zkling
I forget what skill uses those, but they are actually a legit setup to drill from the underside where you need a hole in the only flat side of the object that has to be down on the table for stability. I want to say bowl turners. :headscrat
It's a rockwell radial that someone made adapters for to go on a delta bandsaw? stand.
chicane
Central Virginia
This ^. Also, people please screenshot your Craigslist stuff (as well as provide the link) otherwise it is taken down and no one has a clue as to what you are talking about.
PFSard
Mesa, AZ
I said the same thing when I saw that ad. Thanks to everyone for adjusting my thinking.
olcarguy
I'm right here......
It is missing the foot and is sitting down side up. It is a radial drill press, the section with the motor and chuck more forward or back quite handy press. Normally a lot bigger.
MikeF2316
Thornhill, ON
For posterity...
zkling
The fact that the seller refers to himself as Mr.xxxx tells it all. :spit:
rlitman
Long Island
That would also be called an over-arm drill press.
This however is an under-arm drill press. A similar animal, but needs frequent application of antiperspirant.
1982fxr
Phoenix
well....something told me this one might be up for a day or two;)
