Dayton Speedaire Air Compressor - missing air filter (housing?)
GarageWarrior
Westerly, RI
Need to add missing air filter and retainer/housing to 1.5 HP Dayton Speedaire compressor. Not sure what it had before. There is no filter or housing. Otherwise compressor works fine:
Called Grainger, they said pump is Campbell Hausfeld, but didn't have much info as it's too old for them. I'm thinking that I'll need to get a piece of foam or wool felt to go over the intake opening and make some kind of retainer clip to keep it in place. Found a pic on GovDeals of similar model: looks like a simple metal clip, not sure if it's the original, and where to get it from ...
Suggestions?
Tks
PWC Repair
Arkansas
Looks very similar to my Speedaire. That's the "VT" series pump. It was available with a 2.75 or 3" bore. Mine has a separate valve plate under the head and a complete overhaul kit ran me $80. My filter is just a tad different.
G
GarageWarrior
Westerly, RI
Thanks!
Looks like I found the right parts:
http://www.jackssmallengines.com/Ja...odel-Diagram/campbell-hausfeld/VT235000/966-1
Campbell Hausfeld Single Stage VT Pump Parts:
VT013200AV - Filter Screen
VT014300AV - Filter Retainer
VT013005AV - Filter
Of course as my luck would have it, filter retainer and screen are no longer available. Will need to figure something out.
C96
Hi GarageWarrior,
While you’re at it, remove the head and clean those reed valves. They look very dirty with carbon, dirt and rust. The unit will probably be more efficient with better sealing valves.
Good Luck
Zeke
There is a little picture frame that holds the foam in place on mine. It's a slight different pump though. You can use a little tube on your vac and gently scrape the reeds with clay modeling tools or something you make.
EOC_Jason
Bentonville, AR
Hi GarageWarrior,
Good Luck
+1... That's the first thing I noticed was how dirty the reeds looked! LOL...
