Generator
glider
Flint Michigan
Couldn't find the Harbor Freight coupon thread. I picked this one up today. The reviews looked good and the coupon code is 26674777 for $529.00
theoldwizard1
SE MI
Big boy !
Must have a lot to run. Follow the break in and buy a couple of new spark plugs, either American or Japanese (NGK). The Chinese ones **** and will **** out in probably less than 10 hours of use.
CharlieM
I have the same one. Follow the break in procedure to the T. Mine starts every time on the first pull. Ran 3 days straight when Sandy hit.
G
glider
Flint Michigan
Did a test run today with no problems. I had this panel and plug put in on Friday. I ran most of the house and the furnace. The power will never go out again!
justin1795
blue grass IA
MagicMarker
Can you use that coupon code at the store level? It seemed to work online, but I can't schedule to pick it up at the store.
slip knot
Texas gulf coast
Having a genset is cheap insurance that you'll never need it. Just make sure you exercise it regularly. With e fuel you have to run it regularly.
shocker998md
grantsboro nc
I make sure to run ethonal free fuel in my stuff and stabil it. It gets fresh gas once a year and an oil change after it gets used continually. Last time mine was used was irene but i sure was glad I had one.
I really need to look into the ins and outs of a plug outside.
G
glider
Flint Michigan
So can you explain how this series of breakers function ? Specifically what is the function of the breaker labeled "Main" and "Generator".
The main is the 200 amp disconnect from the pole. The generator 30 amp is what the generator is rated for. Turn the main off and generator on. Feeds the box in the house.
Falcon67
Merkel, TX
Anyone looking at generators need to check out Champion. Their prices are good (maybe not as good as HF) but they stock all of the parts in the US !
They sell a 3100 watt (peak, 2800 watt continuous) inverter generator at a fraction of what Honda and Yamaha sell their same size generators for.
Have a Champion 3500 in the race trailer. Used it a lot this year to run the AC and whatnot. Great thing to have around. The HF units get good reviews, I just caught the Champion on sale as TSC for $299. Then used a TSC coupon to get the wheels. A long RV power cord and some plugs was almost half the generator price! :willy_nil
CJCar
South Central PA
The Wizard must be napping, but I know where he was going...
You need an interlock on those breakers so you can not back feed to the grid. Your install is not up to code and if the power company discovers it they can (and will) disconnect you until it is corrected.
G
glider
Flint Michigan
I brought this up and was told with the new breakers can not back feed. I see what you are saying. It needs to be idiot proof.
