Building a workbench for the 1st time help
ttimpe
Hey guys I'm gonna be building my first work bench. The 1st picture is the bench i am mocking mine after the 2 nd picture is the base I want and the 3 rd is the space I have. I have no wood working skills any expertise or advice would be greatly appreciated.
T
ttimpe
T
ttimpe
1st photo is my space sorry it loaded the pictures wrong
OnAir
Vancouver
* Measure twice (or more), cut once.
* As this sounds like your first woodworking project, I would avoid mortise & tenon joints.
* Keep it simple, square, and level.
* Use screws instead on nails. Stronger, plus it makes things much easier to adjust or disassemble if needed.
T
ttimpe
I looked through that thread @regguy1
brass89
Not sure what you want to do with your work bench.. if it'll be a work bench for wood working, an assembly table more along the lines of a catch all bench for sharpening things, working on parts or maybe just a flat place to do gluing jobs etc.
For wood working you need ridgid and flat.
Mortise and tenon may prove frustrating just starting out, and while screws can work I think a good way to look at most any supporting joint esp holding the top up - avoid just screwing a 2x4 across the sides of posts. Other than timberloks, most screws are quite brittle and don't handle shear forces well. They're meant to hold 2 pieces together, not support weight directly. Instead if you can, think along the lines of using 2 2x4's (or whatever material) glued and screwed together for an upright, one cut shorter than the other. Creating a notch to rest a load bearing cross piece on, then screw together. Then screws aren't bearing the weight.
The first image is not a very strong connection, it relies solely on the screws. The second image is a much stronger connection, fully supported with the screws just holding pieces together. (just as something to consider with pieces which will bear weight, regardless of your actual design)
T
ttimpe
I'm gonna use 4x4 for my legs. It's gonna be a bench to work on bike things I ride bmx and mountain bikes. Just a basic workbench that can handle weekend abuse using 3/4 ply for the top supported by 2x4's
zkling
wintermute gave you a great tutorial. I'd highly recommend tennions 4x4's and 2x4's and through bolts. If you can find a cheap source of butcher block great, otherwise MDF works just dandy. I built mine by myself when I was 10 with a speed square, tape measure, circular saw, chisel, hammer and drill. All those saying to avoid tennions, this is a great place to learn. It's a work bench, not fine furniture.
I think your plan looks good, only thing I might do differently is to make space for a bottom tool box (HF44"?) in that large opening.
T
ttimpe
The red box is my roll around that will fit in the opening when constructed. Thanks wintermute that's some good stuff wish we had that type of place where I live to get lumber and such.
theoldwizard1
SE MI
Set a solid core door atop 2 rollaway base cabinets, with or w/o wheels.
Good idea. Not cheap.
You can also use 3/4" plywood, but I would add a 4" wide piece of 3/4" plywood or 2x4 around all of the edges, for added stiffness.
To attach the top to the rollaway, place blocks of 2x4 on top of the cabinet next to the outer lip of the cabinet. Drill and screw through the lip into the blocks. Place construction adhesive on top of the 2x4s and then place you top on them. Make sure it is square. Add weights. Let sit overnight.
mhoss44
Morrison, Oklahoma
I agree with mortise and tenon. The 2x4 one shorter than the other made post can support a lot of weight, but mostly makes for a good heavy stable bench. The problem I see with the original diagram, the design appears to attach to a wall. That's a big no go for me.
Every time you bang on something, or something heavy on it, it transfers to the wall. Freestanding is the only way to do it. 2 sheets of 1/2 inch plywood makes a good solid top. You can sand and paint for a good surface.
T
ttimpe
Ya not going the mortise and tension didn't notice that one was that . It's gonna be 4x4 not gonna attach to wall unless I need to it sits against my bedroom wall. Thinking. 3/4 ply on top with 2x4 surrounding it
mhoss44
Morrison, Oklahoma
I think that would work great. Maybe some cross braces underneath. One time I built a bench 14 feet long, 27 inches wide. Posts were leftover 8 inch round fence posts, and the top and shelves were leftover treated 1x6. All this leftovers from a backyard fence. I used some 1/2 inch plywood across the top for a good flat surface.
T
ttimpe
Not sure yet my carpenter buddy is gonna help me see what he says
jd_1138
NE Ohio
It's easy for a beginner to start upside down. Put the top of the workbench (MDF, plywood, etc.) on the floor then attach the 2x4's or 4x4's to it and then add your cross pieces and such. Then tilt it over when you are done. That way at least the top will sit level on the legs. And then of course make sure the legs are all the same length before attaching them and are level and plumb.
T
ttimpe
Thanks for the advice
Slednut
Washington state
I built my bench like you would kitchen cabinets. 3/4 inch Plywood framing and I used melamine for the face frames and doors. There are 2x12s built in beneath the bench top.
Keeping all the stuff behind doors keeps it dust free.
