O'Reilly-oil/filter specials and coolant
Ign
Butte Peak ND
O'Reilly's doing 5 qts of their "full" synthetic w Microgard filter again for $19.99
5 qts of Peak dino oil w Microgard filter $12.99
and gallon jugs of 50/50 pre-mix coolant, conventional or Dexcool for $7.99
Thus I got everything pictured for about $77
Fandango
Thanks for the heads up.
I have to ask though, why pay for 50/50 when a gallon of distilled water is less than $1.29?
quattroJoe
FL
Their site lists Dex Cool concentrate at $14.99/gal, add a gallon of distilled water and you're at or over the $16 it would cost to buy two gallons of 50/50 mix.
JDon99
Desoto, MO
Oil/filter prices aren't bad if you don't mind running a Fram filter.
I
Ign
Butte Peak ND
I admit it, I've gladly paid extra for the convenience of pre-mix since it came out. No finding containers in which to mix, perfect proportions and deionized water
http://www.eetcorp.com/antifreeze/antifreeze-faq.htm#q25
http://www.garagejournal.com/forum/showthread.php?t=223730
JDon99
Desoto, MO
If they are now Wix, that is great. I thought they went to Fram in the late 00's?
Edit- I guess they switched from Fram to Wix recently? Good move on their part.
dowmace
KCMO
Distilled will certainly lengthen the life span of pretty much everything involved in your cooling system.
I
Ign
Butte Peak ND
DI water theoretically has virtually all minerals removed. Seems like a good idea to me, esp if you plan on running the coolant for 100-150k or more.
Agreed, my well water is full of fluoride & sodium, an RO system for the house is cost prohibitive.
You can run whatever you like, even GM owners manuals say to just use clean tap water.
The point of the thread (and I thought the point of the Hot Deals subsection) is that if you CHOOSE to run pre-mix coolant this IS a good deal. I just can't be the only member of GJ who elects to buy pre-mix? And I'd guess shops use it extensively for the time-saving and removal of guess work about proper mix?
Rickss96
SoCal
