bubinga
I picked up a nice Hein werner bottle jack at a garage sale today,
And it seemed to jack up and release OK, but the whole nut was turning when
you turn the release valve.
So I backed out the nut all the way and put it in a vise, and used some oil and a little heat from a propane torch to try to free it up.
I got it to turn a little bit, but it only turns about a 1/4 of a turn or less.
Should I use more heat, maybe get it cherry red and try to free it up, or do I need to get a new release valve and nut?
Can I still get the valve and nut?
Also, what is the best way to bleed this jack.
I see some links say to remove the fill plug, and open the release valve and pump the handle 10 to 20 times, but other links do not say to remove the fill plug.
also, what is the process to check/fill the fluid level?
Do I use any hydraulic jack oil, or is there different weights?
Thank You
Thank You
