Clear coat after Legacy epoxy question
Wuaname
Florida
Didn't add this to my thread, since its a specific question
Ok, so I am going to do the clear coat this evening on my Legacy epoxy , which was done yesterday.
I know that you can get 350 - 400 sq ft per gal on the urethane, and my garage is only about 250 sq ft. SO I am wondering if it will be worth while doing two coats of clear? Or just a thicker (if doable) one coat of clear?
I had left over epoxy and primer, so I know I could've gone thicker on those, so not sure if it's now worth a thicker coat or two of clear?
Thanks
Shea
California
Do not put it on thicker. Urethane is not like epoxy. You can get bubbles, clouding, and a possible orange peel effect if put on thick. 2 Thin coats are better than one thick coat. I would recommend applying it as you should and see what you have left over.
Did you apply color flakes? If you have a lot then it takes more urethane. If you have few or none at all then you might have enough left over.
W
Wuaname
Florida
Thanks guys. I applied one coat earlier this evening and of course have clear left. And will apply second coat tomorrow
Shea
California
Definitely worth it if you have enough. It increases the durability over the long run for little investment.
W
Wuaname
Florida
Here is after rhe clear tonight
W
Wuaname
Florida
Pictures like this piss me off.
Nice work. ;)
LOL thanks... Doing the second coat of clear tonight, and done:rocker:
I should've have given it a second coat of the base, but thought I wouldn't need it, so hopefully making up some of the durability issues with the clear coat second coat.
W
Wuaname
Florida
Well I gave it the second coat of clear yesterday evening... I'm done... now just let it cure for a few days.
So far, everyone that has seen it has loved it... definitely good start.
Looks great, nice Job!
Thank you..not too shabby for my first floor.. I can't imagine some of the guys here doing much bigger garages :scared: with epoxy
Very nice sir!
Please PM me name, address and shirt size!
PM sent :D thanks!
