What exact switch do I need for fan & thermostat control?
Air_Cooled_Nut
Portland, Oregon
It's single-poll double-throw, right? Recommendations for a 15A switch? I don't know the proper term (if there is one) for this type of switch. Is it something the big box stores would carry?
My shop came with a thermostat to control the attic fan but I want the ability to manually turn on the fan. So my thought is to wire in a switch in the workspace instead of climbing a 13' ladder, walking across 36' of narrow and low ceiling trusses, and adjusting the thermostat :D
View media item 43940
wyliesdiesels
Modesto, CA
Yes u need a SPDT switch aka a 3-way switch..
Edit: relocating the Tstat doesnt make sense because it wont turn on when the attic is hot!
Rookie2
Western Pa.
or you can install a single pole switch across the thermostat, either way you have to run wire back to the first floor.
Stuart in MN
Minneapolis
This is probably the simplest thing. Just put a regular switch in parallel with it, so when it's flipped on it overrides the thermostat.
Rookie2
Western Pa.
Oh, maybe a dial timer or lighted switch would be a good addition so as not to forget its on
A
Air_Cooled_Nut
Portland, Oregon
Good thinkin' guys! I was over-thinking it. How's this:
View media item 43980The dotted line is where I would connect in at the thermostat.
Yes, illuminated switch is a good idea for when it's ON. I have those neon type ones for my light switches so I can find them in the dark.
