Craftsman / Atlas 101-07301
sleepy127
Flaherty, KY
Craigslist find; Craftsman / Atlas 101-07301
I have been wanting a lathe for quite some time and I found this one on craigslist. It comes with a descent amount of tooling too. Tell me what yall think and if it was worth $500;
tooling pic 1
tooling pic 2
tooling pic 3
sleepy127
Flaherty, KY
Man, I am overwhelmed by all of the replies! Sorry, bad joke. Anyways Chapter 1 in learning to operate a lathe or What I learned today;
1. I cannot center a piece in a 4 jaw chuck without a dial indicator (not sure if I can do it then either)
2. A small paint brush is good for clearing chips out of the way
3. I know so little I don't have a clue what I don't know. I guess I will be opening the books and start from the beginning and order a descent dial indicator.
sleepy127
Flaherty, KY
rsanter
visalia ca
Seems like a good deal to me. You have all the expensive add on stuff like the collet holders, milling attachment, as well as tool holders and tooling....
Now go make something
Bob
Fretters
South Yorkshire, England
Is there ever truly such a thing as a good joke? You can't beat good old fashioned sarcasm, IMHO. :D
Depends on whether you're chucking a piece which needs to be centred else working on raw stock where close enough is fine. If it's raw and you're turning it down somewhat, it'll soon be centred fine.
Aye, a paintbrush is handy, as is a good vacuum cleaner with nozzle.
With regards to books, "The Amateur's Lathe" by Sparey is a good starter reference. One of those books which is always handy to have. Most of it you'll pick up as you go along, and if you get stuck with owt, it's easy enough to just ask advice on here or elsewhere.
Regarding whether you did well on that deal, the cost side of things is open to interpretation, expectations, location etc., but looking at all of that tooling you got with the lathe, and the fact that the lathe itself doesn't appear overly worn or abused?, then I'd say you've done pretty well on that one. If you look at the cost of buying some of those accessories piecemeal, I think you may well find the cost of those alone would likely be coming close to what you payed for the whole thing. Simple things like steadies, for example, can fetch silly money, depending on scarcity. It's usually the tooling and accessories where you get stung on price, if you can even find the parts at all. A haul like that is never one to be sniffed at.
hemifalcon
Union Grove, Wisconsin
Re: Craigslist find; Craftsman / Atlas 101-07301
Just picked up one of these--missing the extra change gears--but otherwise complete and un-abused
sasquatch12
You did very well for $500.00. That milling attachment used, alone sells for around $250.00
Those lathes really hold their value, you'll always get your'e money back if you decide later on to upgrade to a larger one.
Kenwc
It is significantly more than just "worth it". I see two tooling items alone that sell for almost as much as you paid for the whole package.
I have a 12" and it's done everything I've aske it to do.
sasquatch12
Forgot to Mention you also have all the change gears! Great find!! Enjoy and make some chips.
oldldh
Fairhope, AL
The longer you stay and post on this forum...
You will find out that the members here...
Speak three languages---:evil:
English---
Profanity---
And---
SARCASM!!!
Your post tells me that you'll fit right in!!!
sleepy127
Flaherty, KY
Just a little update on this. I got a dial indicator and have been turning a few things. I made a bore gauge for my 30/30 and fixed a mount for the stand on my cman halogen light. I did have to tighten the machine up a little. I also cracked the holder on the end mill attachment. Put way too much torque on it when tightening something down. I took it into work and welded it back up with a rod for cast iron and then milled it when I got it back home. Thinking about making some other type of mount and holder to use it as a mill. When I figure out what I am gonna do I will post it up.
nine4gmc
Dallas
Good score, as mentioned, you have some of the most valuable accessories that are either hard to find or expensive when you do find them. Post up your work, we all love to see pics!
John T
Looks like a good deal
I have pretty much the same.
A qc toolpost is a must.
CoopVA
Virginia
You got a great deal. All that tooling alone is worth more than what you paid.
You ****.
I have the same type lathe. I am in the process of repair and rebuilding / restoration. I am very interested in a photo of your back gear assembly in particular the off-set of the main gear as position on the axis shaft with the secondary gear on the same shaft.
You did well with your purchase, many of the parts and accessories are not available and / or very hard to find.
I downsized my shop in 2020 keeping this lathe and another: type MD-65 series. I also have a milling machine. and old school drill press with a cross feed and rotary table. I will look for your reply.
Thank you, (Studebake Shop) David
I am sure some of you readers will know what I am talking about.
I have a hobby in vintage film cameras. I also have another lathe which I associate with that hobby.
My Peerless-Marshall (watch makers lathe) is used for making the small camera related parts as needed.
This unit has the 12 inch bed which offers a working area of about 6 inches when the head end and tail stock
are positioned to the max extension on the bed. The 3 inch diameter 3 and 4 jaw chucks are turned by a 1/3 HP
motor that has a foot pedal control and belt drive. This is a dry lathe and the man shaft bronze bushings require
oiling before and during each use. I use sewing machine oil to lube it because it is a bit heavier than the suggested 3 in 1 oil.
Like most all full sized lathes this one offers functional collets and a draw bar which can be adapted to different bitts and heads.
Comments are welcomed, (Studebaker Shop) David
