bmxdad
I'm using some 10/2 w/g to hook up a King heater for a 30 amp 240v circuit. Cable from heater is going to a box, where romex is terminated at. I hooked black to black, red to white, and green to bare. Does the white need to be marked red in the sub-panel? If yes, reference in NEC ?
Also, (and no, I'm not doing this) could two separate single pole breakers mimic a single double pole breaker? Is the double pole to insure both feeds are killed on a fault?
