Lightbar brackets for 3" tube
paul2112
Waxahachie,TX
Anyone have any ideas on what I can use for some tube brackets to mount a led light bar on 3" dia tubing ,,, here's a few pics of what's out there allready,,but they r between 60-80 bucks a pair.....Any ideas guys?
RogueFab
Oregon
Get some 3.250 OD .120 wall, cut a .100 slot lengthwise in a piece about 2 inches long, and weld some tabs on for a bolt closure. Make a hinge if needed for installation. Add a tab for your light bar. Now make another. Powder coat and *bling* you're done.
Hmm. Makes $60 seem like a good deal.
Hose Clamps! (Not serious).
aczr2k
NW Minnesota
Make some than the $60-80 seems cheap. You can use a 3" clamp collar and tap a mounting hole in it. I've done that for 1-3/4" tube.
Epoxy? Are you serious? I'm not trusting my light bar to epoxied on brackets.
aka Larry
Eastern, NC
Muffler clamp. I modified a pair to work as a camera mount on the roll bar in my race car. I used a rubber sewer coupling for a cushion between the bar and the clamp and it works like a champ. I also mounted a panoramic rearview mirror to the halo bar of the roll cage by using a pair of muffler clamps and welding on a couple of tabs. If you can weld, it will be easy-peasy to make what you want.
Stooge
South Shore, MA
Lol, Are you serious? Current Industrial and commercial grade epoxies and adhesives are used to support a hell of a lot more than something as lightweight as an offroad lightbar. But what do i know, i just work for a tensile strength testing manufacture:dunno:
aczr2k
NW Minnesota
Yeah because everyone gas access to industrial grade epoxy. When you say epoxy most people think of jb weld.
383 240z
Findley Twp. Allegheny Co.
I think these are pretty bad ***.
http://www.4wd.com/Jeep-Bumpers-Jee...7n6_MZMBmn8AEc_D9iP_mIPgq3Xd_ihNFmxoCzG_w_wcB
$22
images.ashx
Kevin54
MEMBER EMERITUS
Urbana, Ohio
How many do you need altogether? Check your PM's
P
paul2112
Waxahachie,TX
Here's what im attaching the light bar to,,,,3" stainless bullbar
R.Anderson
Wisconsin
How pretty do you want it lol Stainless hose clamp to fit around the 3" tube and a piece of aluminum or stainless flat stock few inches long with a hole for mounting the light and bent 90° to go under the hose clamp. Hell lot cheaper and it works. To make it better take the part that goes under the hose and pound a radius to fit the tube.
