Denwood asked about the salt spray test I did with Fluid Film back in '07-08 (he has similar thread going on about CPC on Samba forums), figured I'd list the results here:
As you can see Fluid Film, CRC Heavy Duty CPC, and Johnson Triple Guard Grease did well. Boeshild T9, Boiled Linseed Oil, and WD40 did not do well.
Here my notes from the test:
Started 10/26/07 - all coupons were cleaned to bare metal with a grinder and deburred. Before application of CPC, coupons were cleaned with mineral spirits
12/22/07 Inspected and photographed all coupons.
Found visible rust only on bare/wd40 coupon (both top and bottom). Linseeed oil turned brown color in few spots, making it difficult to see the metal underneath.
Sprayed salt water on all coupons on both sides
12/23/07 Inspected all coupons.
Found abundance of rust spots on unprotected/wd40 coupon, with a few spots exibiting heavy rust formation. Very light rust started to form on coupon covered with boiled linseed oil
12/27/07 Inspected and photographed all coupons.
Results:
Wd40/clear -heavy spot rust
Linseed Oil -spot rust, mostly in the top half
Boeshield T9 -light spot rust, mostly in the top half
2/3/08
Fluid Film, CRC, Johnson - no rust on
T9 - rusted top half
Linseed Oil - heavy rust, mostly top half
Unprotected - rusted uniformly
6/1/08 - finished testing, wiped down all coupons with cleaner
Fluid Film - no rust on
CRC - slight rust in the corners and by the scratch
Johnson - slight rust in the corners
Linceed Oil - very heavy rust
Advantage of Fluid Film over hard film CPC (like CRC) is that it remain liquid and will self-heal minor scratches. Disadvantage is that it's messy to handle and attracts dirt (but easy to clean when needed).
