Beginner's luck--Walker Model 882
D
dchasins
Western NC
Well, apologies to any and all who might be taking a look at this rebuild project. I've been traveling this summer, and having had to farm out some machine work, I had an extended period with no updates. But I haven't abandoned the work...
So, in the meantime, I have been sandblasting and cleaning parts, and have collected the parts that had to have machining. Renews my commitment that I have to find a lathe--but probably not until I have built a new shop. That will be a story in itself.
First, some good news from the clean up. A prior rebuild of this jack painted everything dark blue--and I mean everything. I've mostly been scraping and sandblasting to make a good base for repainting. Some rusty parts have been cleaned using electrolysis. After a rebuild by a good local hydraulic shop, using a parts kit sourced on eBay, I started to get the cylinder ready for paint. I found to my amazement that the original decal was still on the barrel, and if I was careful I could chip the paint off and preserve what was left. Believe it or not, the best tool I could find to carefully take off the dark blue with minimal damage to the decal was my thumbnail. Whew... Here is how the cylinder is looking now...
[URL=http://s1212.photobucket.com/user/DMSKAuto/media/Walker%20jack/IMGP0001.jpg.html] [/URL]
And a close up of the decal, which I think I will leave as it is, since it is original and has some "patina":
[URL=http://s1212.photobucket.com/user/DMSKAuto/media/Walker%20jack/IMGP0002.jpg.html] [/URL]
Next, here is an update on how I am solving the two worst problems I found on the jack. The first is the axles for the rear swivel casters. As seen in the earlier photos, the original axles were worn almost half away from use under weight. There appeared to be no original bushings...just a steel wheel on an axle. I decided to upgrade to a more robust solution, using sealed needle bearings, two per wheel, with new axles made of hardened steel. I sourced the shaft material and the bearings from McMaster-Carr. If anyone wants the specs, post up and I will be happy to provide the info. Both the wheels and the caster shells had to be bored. The wheels were bored to accept the needle bearings, and the shells were bored to take a light press fit from the new axles. The axles were cut to length and grooves machined for "E" clips, for a neater, more compact assembly and ease of future rebuilding...though I think this assembly will outlast me! The rated capacity of components used totals more than the capacity of the jack (2 ton). Here are the pieces for the rear casters:
[URL=http://s1212.photobucket.com/user/DMSKAuto/media/Walker%20jack/IMGP0004.jpg.html] [/URL]
[URL=http://s1212.photobucket.com/user/DMSKAuto/media/Walker%20jack/IMGP0007.jpg.html] [/URL]
Next problem was the badly worn handle pivot bore in the right side casting (see above...) My solution was to have the handle pin turned down to fit a heavy duty steel/bronze alloy oil impregnated bushing (also sourced from McMaster-Carr). I had the machine shop turn the down the pin, and bore out the oval hole in the side casting to specs for a press fit of the bushing. This solution is also substantially more robust than the original steel pin to casting design, due to the "super oilite" bushing, and it will resolve the side-to-side play in the handle. Here are how the parts look now:
[URL=http://s1212.photobucket.com/user/DMSKAuto/media/Walker%20jack/IMGP0005.jpg.html] [/URL]
[URL=http://s1212.photobucket.com/user/DMSKAuto/media/Walker%20jack/IMGP0006.jpg.html] [/URL]
Well, that's about it for current updates. Here in Michigan it's already feeling like fall. I need a couple of nice days to finish part prep and do some painting...then assembly. Thanks for following along! More to come.
Sheriff Roscoe
Great Lakes State
Very nice dchasins and I like how you're documenting the resto project.
BTW, I'm just down the street from you in Lake Orion. Hopefully, we won't compete too much on Craigslist deals! :D
D
dchasins
Western NC
So, here is another update on progress with the Walker 882. It's almost done, so here are a few more pictures of what I've been doing.
After, sandblasting all the parts, it was time to start painting. I decided to go with the original scheme as far as the layout. I didn't have any luck discovering originall paint formulas, so I chose the colors from the fleet selector colors from Dupont. I did decide to use a blue that has a very fine metallic content to give a slightly more modern look. I used a 2k epoxy primer/sealer before applying Fulthane 2k urethane finish.
First step after sealing everything was to apply the yellow to the handle, wheels, saddle, etc.:
[URL=http://s1212.photobucket.com/user/DMSKAuto/media/Walker%20jack/IMGP0008.jpg.html] [/URL]
[URL=http://s1212.photobucket.com/user/DMSKAuto/media/Walker%20jack/IMGP0009.jpg.html] [/URL]
Next, I applied the blue to the inners and hard to reach areas with the jack disassembled:
[URL=http://s1212.photobucket.com/user/DMSKAuto/media/Walker%20jack/IMGP0014.jpg.html] [/URL]
[URL=http://s1212.photobucket.com/user/DMSKAuto/media/Walker%20jack/IMGP0013.jpg.html] [/URL]
Then, I assembled the main frame and handle components, leaving off the wheel assemblies to finish painting the blue:
[URL=http://s1212.photobucket.com/user/DMSKAuto/media/Walker%20jack/IMGP0020.jpg.html] [/URL]
[URL=http://s1212.photobucket.com/user/DMSKAuto/media/Walker%20jack/IMGP0022.jpg.html] [/URL]
[URL=http://s1212.photobucket.com/user/DMSKAuto/media/Walker%20jack/IMGP0023.jpg.html] [/URL]
One of the things that I decided to do in this rebuild was to make it easier to take the jack apart and reassemble if it should ever be needed. That meant finding a different solution to some of the staked rivets that were originally used for things like locating the front axle in the frame sides. I decided to use stainless pins with e-clips, sourced from McMaster-Carr. Easier to assemble, easier to take apart if necessary:
[URL=http://s1212.photobucket.com/user/DMSKAuto/media/Walker%20jack/IMGP0019.jpg.html] [/URL]
Similar approach to the reassembly of the rear caster wheels. The parts were shown in an earlier post. New axles, machined from hardened shaft stock, and grooved for e-clips. Light press fit in the caster frames, and inserted through the wheels fitted with needle bearings:
[URL=http://s1212.photobucket.com/user/DMSKAuto/media/Walker%20jack/IMGP0024.jpg.html] [/URL]
[URL=http://s1212.photobucket.com/user/DMSKAuto/media/Walker%20jack/IMGP0025.jpg.html] [/URL]
Think I'll leave it at that for now. More pics of final assembly and hand painting the white details on frame and cover to follow. Hope it's interesting to see how I have chosen to bring this heavy duty jack back up to nice condition. It will be my main service jack for heavier work, backed up by my Hein-Werner O'boy from about 1982.
D
dchasins
Western NC
A little more on reassembly and detail painting. I'm hoping that the project will be done this weekend...
The front wheels are yellow on the outside, and blue on the inside. I'm not a fan of the cotter pins that were used for the wheel retainers, so I had planned to try using the clevis pins in the first picture:
[URL=http://s1212.photobucket.com/user/DMSKAuto/media/Walker%20jack/IMGP0026.jpg.html] [/URL]
It turned out that there wasn't enough room to fit clevis pins above, so in the end, I used the same stainless pins with "e" clips as I had used on the front axle. I am satisfied that it gave a secure fit and ease of removal if needed. The end result looked like this:
[URL=http://s1212.photobucket.com/user/DMSKAuto/media/Walker%20jack/IMGP0027.jpg.html] [/URL]
One of the last steps in the rebuild is to add back the white detailing that was part of the original factory scheme. I decided to do this using pinstriper's tools and "One Shot" paint. I found that a combination of freehand and masking with 3M fine line tape on the straight edges gave me the best result:
[URL=http://s1212.photobucket.com/user/DMSKAuto/media/Walker%20jack/IMGP0028.jpg.html] [/URL]
[URL=http://s1212.photobucket.com/user/DMSKAuto/media/Walker%20jack/IMGP0031.jpg.html] [/URL]
[URL=http://s1212.photobucket.com/user/DMSKAuto/media/Walker%20jack/IMGP0032.jpg.html] [/URL]
[URL=http://s1212.photobucket.com/user/DMSKAuto/media/Walker%20jack/IMGP0034.jpg.html] [/URL]
[URL=http://s1212.photobucket.com/user/DMSKAuto/media/Walker%20jack/IMGP0035.jpg.html] [/URL]
That's as far as I've gone through today. A little more to do with the white details, and then it should be complete. Final pix to follow shortly. Thanks for following along...
fourjeepin
Atlanta, GA
How many people went put to craigslist to check for one of these after seeing this thread? None available in the Atlanta area. :( Though I don't need another project.
D
dchasins
Western NC
fourjeepin: Well, you might be right, some people might be reminded that CL can have some hidden treasures. I often find things I am looking for...sometimes it takes quite a while, sometimes you get lucky. This one was a complete surprise. Literally the first search turned up my Walker 882. Purchase price was great, but I probably put more into it in parts, paint, machining and hydraulic rebuild than I should have. On the other hand, I will get tons of use out of it, and it will outlast me. Plus, I had a lot of fun doing the rebuild and writing my first thread on GJ. BTW, everybody needs another project...;)
D
dchasins
Western NC
Here's the last official post... The jack is all done and ready for duty! It's pretty cool to see the result of the earlier work come together, and I'm stoked to be able to use the jack. And I'll be putting my import 3-ton on CL soon.
As a reminder for anybody who is looking at this from the back end first...here is what the jack looked like when I brought it home:
[URL=http://s1212.photobucket.com/user/DMSKAuto/media/Walker%20jack/Walker_1.jpg.html] [/URL]
And here are a few shots after the rebuild and refinishing process, fresh in its (close as I could make it) factory paint scheme:
[URL=http://s1212.photobucket.com/user/DMSKAuto/media/Walker%20jack/IMGP0037.jpg.html] [/URL]
[URL=http://s1212.photobucket.com/user/DMSKAuto/media/Walker%20jack/IMGP0039.jpg.html] [/URL]
Works like a champ:
[URL=http://s1212.photobucket.com/user/DMSKAuto/media/Walker%20jack/IMGP0040.jpg.html] [/URL]
If you've followed the progress, I hope it's been interesting. Anyone having questions about the process, parts used, etc., please feel free to post up. Lurking on a few other threads, I've kind of taken a liking to another cool old jack...the Blackhawk SJ-18. Maybe I should start looking on Craigslist! :eyecrazy:
D
dchasins
Western NC
X2. Awesome job and great documentation. Now I know what I want for Christmas...
Thanks for the feedback! It was a fun project, and I've been using the Walker as my main jack for the last few weeks, and it's a pleasure to use. Sturdy, stable and smooth... I'd recommend one to anybody who happens to find one that's complete. As others have said, these jacks were built to be heavy duty units and will take a lot of abuse. Like so many on GJ, I enjoy bringing a good old piece of equipment back to original condition, and also enjoy using it as it was meant to used.
123Go
fwiw-
There is a nice complete (non lifting) Walker 882 C series Tom Boy on EBay at the moment for $100 obo + shipping if needed. I had an offer in to buy it but I pulled my bid after learning these only have a 20" max lift height, same as my shorty Walker/Werner.
Thought I'd let members know about it anyway.
I just prefer the height on my Hein Werner M series with 25" lift height so it would have been a big step down for me. I just had no idea mine raises so much higher, I wanted a long Walker for yrs. I do see their 4 ton matches my M models lift I must say it shocked me learning this actually. Peace
