The Detailer
I don't have access to air so my options are either corded or lithium. I saw a couple videos on a very nice Bosch 26618 doing lug nut removals no problem. Have any of you guys ever used an 18v or higher on wheels?
Wow, the Milwaukee is badass but definitely out of my price range. I already ordered the Bosch but I can return it. I wasn't sure about the 1/4 drive but for the price I got it for plus a nice Bosch dds181, I definitely can't complain.
Anything "high torque" like a W7150 or similar should get the job done just fine.
I used to do them with my brushless 18v hex driver and an adapter... it would get small car lug nuts off, if they weren't overtorqued, or rusty. That's about it. These days I have a brushless (MW Fuel) 3/8 square drive gun, it's good for probably 3 out of 4. Again, overtorqued or screwed up threads, probably not gonna happen.
I'd look for somewhere around 400 ft/lb to do wheels reliably.
I really like my Hitachi 1/4" hex impact but if lug nuts are a primary concern I'd get an 18V impact wrench for a few key reasons.
1) Many here suggest the impact wrenches have more of their torque geared towards loosening, unlike an impact driver's which is geared towards tightening.
2) Less or no torque loss compared to what you will see with the 1/4" hex to square adapter (some disagreement on this topic, but certainly nobody is arguing that you'll get more torque with the 1/4" hex to square adapter).
3) You can run a square to hex adapter on a wrench and still use it for most of your driving needs.
In regards to point three, I find that most of the time that I use my impact driver as a driver I'm not all that worried about clearance in tight spaces. In fact most of the time I use it as a driver I have some sort of magnetic bit holder on it like this:
I rarely find myself popping off the magnetic bit hold to get more clearance when using it as a driver. On the other hand, when I use my driver with a hex to square adapter for socket use I'm often in tight spaces and want the tool and socket to take up the least space possible.
The upshot is that I think I'd prefer to use a wrench with a 1/4" driver adapter than my current setup. To be fair I haven't tried much less owned this setup so it's an educated guess at best.
Lastly, if you're sold on the Bosch 18V tool system they do make a 1/2" impact wrench/driver hybrid. 1/2" impact wrench combined with a 1/4" hex female drive.
It doesn't have bad reviews per se but it tests it doesn't seem to keep up with some of the other impact drivers and wrenches it is meant to replace.
If my Hitachi died today I'd go out and get a Milwaukee 18V Fuel compact 3/8" wrench. I'd justify the cost by getting a few 3/8" square to 1/4" hex adapters for my various tool boxes and then only having to own one tool.
If your case you might more power than the 3/8" Fuel, but same logic would apply.
Basically, my needs are simple. I'm not removing constantly, about once or twice a month (wheels). I'm removing misc stuff for cleaning such as throttle bodies etc. again this is more of a finishing touch rather than a full tear down.
For anything rusted, I definitely figure it wouldn't get it off. I do have a breaker bar for the heavy duty stuff. This is more or less to just make the removal faster and stay away from cords obviously.
Yes, the Milwaukee 2763 will take off anything the Milwaukee 2654 or 2655 will not, which so far for me they have had no trouble. 2654/55 are rated to about 200 lb-ft, 2763 is rated a LOT higher.
I've been using the Sears/Craftsman C3 (19.2 volt) cordless tools since 2006 and LOVE them.
I use the 1/2" impact to bust the lugs nuts off and back on again on my NASCAR stock car all day long at the track.
I think Sears/CM has (or just had) a sale on the 1/2" impact and variable speed drill.
ttp://www.craftsman.com/craftsman-19.2v-c3-mechanics-combo/p-00917229000P?prdNo=11&blockNo=11&blockType=G11
Includes two batteries and the multi-chemistry charger. $160. Save $90. Great deal!
Ugh, I wish I would have saw this before hand! I feel bad now, the guy just shipped them this afternoon and the bosch is probably already going back thanks to you guys![]()
If you are going C3 it might be worth considering the newer HD 1/2" torque wrench, it is 300 ft-lbs vs. 200 for the older model, picked one up on sale for $150 and like it, came with a 4 ah XCP battery and a charger, spins lug nuts off FAST.
A smaller 12V 1/4 hex drive impact driver is well worth having too, the lower weight and size is a big advantage for smaller fasteners and is much less likely to overtorque them, use mine constantly for mechanical work on cars, motorcycles, etc.
http://ecx.images-amazon.com/images/I/51I3A%2B2Lp%2BL._SL1000_.jpg[IMG][/QUOTE]
I recently picked up this newer model on sale for $150 with the 4ah battery. Very impressed for the price (and it uses the same batteries as the 19.2 (pre C3) tools I got 12 years ago for Christmas from my dad).
I recently used it to remove/replace all 32 165ft*lb lugs on my F250, along with all the bolts/nuts needed to swap out the front shocks, replace the ball joints, etc, and rotate two other sets of tires on two of our other cars all on one charge.
I love my C3 1/2 impact with LiIon batts. I also have the big boy milwaukee fuel 1/2 and that thing is heavy and it is a beast
Heck, I use my M12 to remove lugs.. Granted, it's only on my F150 and CJ7, and I'm pretty neurotic about rotating tires and keeping threads clean...
It's amazing the variety of results people have or maybe the guns vary that much in power?you got a guy taking axle nuts off with one and the next will claim it won't even move a low torque lug nut.
