1 1/4" emt offset for subpanel question
gpalmer77
Mokena IL
I have to create an offset from where the conduit comes up through the sillplate about a half inch from the outside wall (2x6 wall) to the entry point into the bottom off the box which is flush mounted for 1/2" ply. I'd guess a 4" total offset over a 4'-6" run of conduit. Can I do this without a bender or will the emt collapse and kink? I only have 1/2" and 3/4" emt benders. Thoughts please.
pattenp
Virginia - USA
You could try to use two rigid offset ******* coupled together.
Well..actually that might not be enough of an offset. It may take 3 or 4 of them. Never mind, the flex is a better solution.
G
gpalmer77
Mokena IL
Is flex okay to be buried inside the wall, behind plywood? Does that meet code? (i'm not questioning, just asking because I don't know.)
And this is the same stuff as seal-tite, right?
Excuse my idiocy. I usually only work on the distribution side of the box.
brewchief
Find a local electrician who will bend an offset for you at his shop before he heads off to the jobsite.
Eriehunter
^^^ or they sell pre-made bends at the supply house and you'll need to get some extra couplings
C96
There’s always a muffler shop that could do it. The radius is different, but for a small offset when you’re in a jam, well…
Fyrme
Green country, Oklahoma
If you haven't already gone the flex conduit route, you can bend 1 1/4" without a bender. I've done it several times in a pinch. Just need a heavy truck or trailer and use the frame and tire. It won't look perfect, but behind a wall would be a perfect place to use it. However, if the parts house is close, and you've got the money and time, I'd use pre made bends or flex in that order.
G
gpalmer77
Mokena IL
Done. Turns out it was only about 2" of offset required, I did it by hand using the hitch on my truck. Came out fine for something that will be hidden inside the wall. Thank you for all the suggestions.
bmxdad
Puyallup, WA
I know you fixed it, but could you have gone to some schedule 40 and heat it up so it was soft enough to bend.
I used Sch 40 under my pad and a pipe heater, to soften them up, to get them to line up.
View media item 43839
