Compression - Show Off Your Compressor
hondacivic247
I figured out that it's a champion model ren-14 never herd of that model if anyone has any info on the specs and hp requirement let me know it's currently try got a 5hp leeson motor
Xicaque
I move every 2.5-3 yrs. No choice.
Just kidding. One of these days though. Currently 216 quincy 5hp pictures to follow but I am scheming on a 5hp IR single phase screw compressor at work. Used unit been sitting for a while. Pretty much a unicorn.
This is so ****! Love those curves :pimpflash Got video of it working?
stikman56
Found this on Craigslist, close to me too. Guy had hardly used it,decided bodywork wasn't going to be his thing. He wanted $300.00. I had the nerve to ask if he'd help me load it, as I was by myself.....he said "sure".
toyoguy81
Missouri
60 Gallon American Industrial with upgraded 3 cylinder Puma PUK65 pump. Rated at 21.5 cfm. Craigslist find, been searching forever and almost pulled the trigger on a Puma 6060V, then saw this for not much more!! Can't wait to get it hooked up and see how she fares..
catfish500 mark
This is my new Curtis.I got it last week.Still working on getting it setup and the new electrical hooked up.Once its all done I will post some pics of my entire system.
Ray_PA
PA
I picked this one up used on Craigslist. Speedaire (Grainger Name) 23.5 CFM @ 175 PSI. with 80 gal. tank. Speedaire is made by Champion for Grainger. The compressor originally had a 7.5 HP 3 phase motor on it. The person who owned it purchased the 7.5 HP single phase motor that is on it now and never finished the project. The motor alone cost over $900.00 at Graingers. I picked it up along with the motor starter. Working on wiring it now.
ChadTexas
Amarillo Tx
Here is my little air compressor. I use it to air up the tires and blow off dust around the garage. What I really like about it being under the tool cart is that I can roll it around. I typically put my miter saw on top and roll it out into the driveway and then I have some compressed air right there to blow all the saw dust away.
[/url]
DSC02680 by cawthon_engineering, on Flickr[/IMG]
MacMcMacmac
canada
Would love to see some of the ones you work on, if it isn't against the rules!
This is one I was working on last week, 1952 Brown-Boveri, 6000hp. 23,000cfm @ 100psig.
This is not the biggest machine we have....
hondacivic247
Does anyone here know the cfm and pump rpm/hp for a old champion 80 gallon with a ren14 pump. Found one on Craigslist that needs some work is leaking oil but already has a 5hp single phase motor. I may get it if the quincy 325 I've been trying to get to for weeks sells... can't stand not having a truck anymore..
Model # is tuv57
MacMcMacmac
canada
Google searches return this unit as a 3hp compressor, so it will not be putting out the same amount of air as a 325. It looks like an older, all cast-iron design.
When we were selling Champion back in the 90's, their brochure stated at that time that they would still build their pumps as all cast-iron if the customer requested it.
On-Wheel
Any info on a Champion RE-10-9A.I'm thinking late 40's mid 50's.It's stamped 9498 on other side of belt side.
hondacivic247
I was thinking that the ren14 was the older Version of the r15 champion pump they now offer. I read somewhere that it the ren7,10,14 produced between 7cfm and 19cfm so I was assuming that the ren14 was the big bad boy as it listed 5hp. From the picture it looks to have a big bore and stroke like the R15. Only issue I've found is that they don't produce parts for it anymore.
To the guy aboe with the champion that looks like a ren-10 model which is prolly 3hp and around 8cfm @175 I believe I read
hondacivic247
Here's some air compressor I restored a emglo gt with a 8in pulley and 5hp 184t frame Weg motor making 21.5cfm @125 and 18.4@175. Next was a Rolair k25 making 13 @125psi. Then my first compressor 1984 sanborn single stage v-twin,1hp. Sold all of them and made enough money to now buy a quincy 325/saylor beal/kellogg compressor. That emglo was a great compressor it could fill that 60 gallon tank to 175psi in 5 mins 30 seconds with a 8in pulley on that big weg motor
MacMcMacmac
canada
Could be. It looks a lot like some of the older Dayton branded stuff from Grainger.
On-Wheel
Took awhile but I found valves for the Champion RE-10.When I took manifold off there was a copper crush below valve.Should there be a copper crush on top of valve,between manifold ?New valve kit has copper crush,silver(aluminum) crush.Does the silver one go between valve and manifold ?
I changed oil in it and it spins smooth but might need new bearings.And it leaks.
I saved it from going to the dump.The owner gave me the newish 2 hp for $25. It's on a 120 gl propane tank.It did pump even with valve springs half gone.
customcabinetpro
I wasn't planing on buying a new compressor, but my original Quincy QR 325 ( in an earlier post) tank sprung a leak over Thanksgiving, and I was starting to get nervous as to what was next with the old boy, especially since I noticed the rear seal had started to fail again after 2 years. I was originally going to just replace the tank, but the place I got the tank from gave me one heck of a deal on a new tank, new 2 stage 2 cylinder pump, all the fittings, and the belt guard for half the cost of a complete new one, and since the motor and all the electrics on my Quincy were replaced a couple of years ago, I just used them on the new one. So basically I came home with an un-assembled compressor kit.
Here's my new 2 stage compressor I purchased from Air Compressors Plus. The pump is made my Castair in northern Minnesota. I'm running it at 792 RPM with a Baldor L1410T motor good for a max FLA of 26.5, but the actual load is 21-22 amps at it cut out pressure of 175 PSI.
Specs:
17.5 CFM @175psi at 767 RPM
catfish500 mark
My new compressor.I weakened 2 of the 3 cylinders on my old compressor by letting it run too long using the sand blaster.It said 100% cycle duty and only ran for maybe 30 mins straight but it still damaged the reed valves.Its was a Kobalt 5hp 3 cylinder rated at 19.5 cfm at 90psi.I emphasize (RATED).After a ton of research I settled on this one and so far I couldnt be more satisfied with its performance. Noise level is quiet high though but with its output 29.9 at 90psi it runs very little so it really hasn't been an issue so far.The electrical needs had to be upgraded and that cost almost half of the cost of the compressor itself.The black hose reel is for filtered air used for painting, sand blasting and the plasma cutter.The red hose reel is just straight un filtered air used for blowing out the shop, filling tires or whatever doesnt require running the air dryer.It was a learning process and I spent more money than I intended but like the ole saying goes, good aint cheap and cheap aint good.
danny_barkley
FL
Nice setup and nice compressor!
How much was the electrical work, I am wondering that myself.
catfish500 mark
Two sub panels,100ft 4-4-4-6 wire, conduit,2 ground rods, breakers, connectors, trencher rental and a few things that Im sure Im forgetting was around $1000.00.Something to keep in mind when upgrading to a compressor of this size.Thanks for the kind words:thumbup:
louisiana
champion compressor model ren10 desperately need connecting rod bearings please help
amac70
St Helens Or
Don't think i ever posted pics of my compressor in this thread, re did this last year still haven't finished the cooler set up but it running as is right now. first pic is sort of how i got it second is what it looks like now.
