Cost Question
jy211
Miami Florida
does $8 per sq ft sound reasonable for a metallic epoxy floor coating?
Will be done in a garage.
benwah
Crested Butte, Colorado
Depends on what kind of surface prep is being done, what manufacturer and products are being used, and what type of system you are going for. Care to provide more information?
LegacyIndustrial
deerfield, IL
Keep in mind that without flakes/chips to hide all your sins the installer is forced to make sure every blemish is filled and ground. This eats time and money.
chruler
Vermont
It's all about the prep work. (Like anything in life)
I used to do linoleum and tile and a lot of time was often spent prepping the floor.
Even a less expensive product will last a lot longer if the prep work is done properly.
J
jy211
Miami Florida
the $8 pr ft is just the metallic and clear. They are charging $850 for "clean and prep floor. Will do a 1 step grinding to open the concrete and clean all contaminates from surface.
Jinks
Daytona Beach
Assuming a standard 2 car garage the price is now $10 a square foot, or about $4500.
J
jy211
Miami Florida
Thanks. Gives me an idea. I have a 3 car garage and its roughly 656 sq ft. Just wanted to see if the $$ was in line
