How did this pass quality control?
coleman10
Fort Lauderdale, FL
Got this out of a 4-pack of screwdrivers (two slotted, two Phillips) that was given to me. This one seems to be missing something. It's not broken, it's just missing. It's even coated at the end.
I'm not sure if I should bring it back for an exchange or just keep it as a novelty.
Anyone else ever receive a totally messed up or malformed tool?
DocsMachine
Look at the end jammed into the handle. Does it have a head of some sort on it? :D
Local mini-museum has a bunch of old tools, and to go along with it, a relatively new, still-in-the-shrinkwrap pair of Stanley screwdrivers. Ostensibly a set, standard and phillips. One of the pair had the shaft pressed into the handle backwards- all you could see is a straight, round shank that'd had two "wings" pressed in so it'd bite better into the handle.
Keep it as a novelty. :)
Doc.
C
coleman10
Fort Lauderdale, FL
Doc.
Ding, ding, ding! Give the man an cigar!
After reading your post, I took a look inside the handle and, sure enough, there's the tip! Yeah, I'm keeping this one. I doubt I'll see this again.
brass89
Would be sweet to have a whole set of them. Different sized handles and shanks. Put them on a rack as a 'set' and ask someone to grab you a screwdriver. lmao
RonnieC
Orlando, FL
Quality control usually means examining a small sample of the output and saying "If .05% of these are right, then all of them must be good."
rslaback
Westcentral Wisconsin
One type of quality control, yes. Specifically it is called acceptance sampling.
There are different types of quality control of which acceptance sampling is one. Other products (pacemakers for example) are each individually tested.
Bruce Lancaster
Just a new OSHA requirement...they have discovered that if the tip is assembled into the handle thus it can't scratch anyone. They'll all be like this once old stock is out of the store.
