Sourcing a spacer
rslaback
Westcentral Wisconsin
I have a project that I am working on that needs quite a few 1/2 x 3/4 x 1/2 steel spacers. I'm sure someone must mass produce these but I'm not finding them at MSC, Fastenal or Hillman. Any other suggestions? I could turn them all but in terms of time I'd prefer not to.
larry_g
oregon
I found arbor spacers in .5 x .75 but a max .125 length. Misumi might be an option but their standard spacers did not have your id x od listed so you would have to contact them. Travers has some 1/2" stub arbors with spacers included but no listing for separate spacers.
Good luck
lg
no neat sig line
kf4zht
Calhoun, GA
At $3.50 each you could quickly pay for a band saw / cold saw etc and cut them out of pipe.
How many do you need?
Yeah, get the right size tube and setup a saw with a stop. You or a trained helper could knock out quite a few per hour.
DenisG
Milwaukee
You can get common 1/2" hex nuts 31/64" high and drill them out. Probably the cheapest option, but not knowing the tolerances you need or the application, I can only guess.
Brians VWss
INLAND EMPIRE
That's what I would recommend a bandsaw or what ever you have to cut it with and some 3/4 x1/2 DOM Tubing, asit is smooth on the inside
gte718p
This assuming you don't need a precision spacer. The reason spacers are expensive is they are cut, and then ground to a tolerance. Three step process. good parallel spacers are easy, but tedious to make if you need them to be extremely parallel and flat.
KenS
...cut it with some 3/4 x1/2 DOM Tubing, as it is smooth on the inside
Brian's correct-- pipe will have the welded seam down the bore. But when you consider the high price of DOM and the time spent machining the spacers, it might well be cheaper to buy them.
I guess it depends on how many the OP needs, and the time frame in which he needs them.
R
rslaback
I'm going to end up needing about 40 of them total. They aren't precise and do have to be round for the application. I'd figured my best was going to be a drop of whatever DOM the local supplier has and bore it out to 1/2" if needed and then part them. I'd considered using my chop saw or bandsaw but I want something a bit smoother and without the burn mark from a chop saw.
A_Pmech
IL
Dom tubing and a parting tool in the lathe. About a 45 minute job.
tstaude
SE Wisconsin
Call up Bullseye Industries in Juneau, WI
I have had good experiences with these guys, excellent price and delivery.
dtt454
missouri
cat part number 4e1303 spacer, inside diameter 13 mm outside diameter 20 mm thickness 12.5 mm
list price is 9.18 each though.
