Super glue for cuts?
Kin Creed
Minneapolis, MN
I was watching Gearz with Stacey David and he suggested using a type of medical super glue for minor cuts. Has anyone tried this? It looks like a pretty cool first aid technique, in general and particularly for shop use.
Band aids can be a hassle, especially on fingers you intend to keep using.
road
Hamilton, Ontario
I sliced my forearm a few years ago and at the emerg the doctor used it on the 2" cut.
Since then , I use it all the time. I keep a tube of Krazy glue fast setting in my fist aid box and in the shop.
Keystone79
Florida
I heard that the medical grade stuff is just regular cyanoacrylate with a purple dye in it. I've been using kimball Midwest super glue on cuts for 5+ years now.
BFHtime
This is not medical medical advice, what you do with your body you do at your own risk. Legal disclaimer.
The purple type with a brush is the one you want. It is the same chemically as surgical glue, just not certified sterile. If you can get both sides of the opposed skin together without a gap, it will look very neat, you may have trouble finding the scar.
colt zantop
michigan
Yup....I've used it more than once. The best time was when I was a student at wyotech and sliced my finger with a razor. I had perfect attendance and I had 2 options...go to the hospital for a couple stitches and lose my perfect attendance or run across the street to walmart for " break" and get some glue. Choose option #2 . :)
Thumper68
Duluth MN
Been doing this for years, the wife is a hair stylist and learned it from her. I keep several of the small tubes sealed in packets in the shop and first aid kit. May not bee 100% sterile. but close enough if you only use each tube once.
wild cowboy
Birmingham
Hospitals routinely use super glue (cyanoacrylate) for slice wounds, a practice that started over 25 years ago!
And it doesn't have to be "medical grade" either - I wouldn't use the cheapest generic Chinese ****, but any famous name super glue is fine, such as Loctite's original Super Glue, Krazy Glue etc. would be perfect - I have done it 100 times! - but do use a freshly opened tube, if possible, for cleanliness.
Not only does it hold the wound together for perfect healing and alignment of tissues, it also acts as a barrier to bacterial infection!
for once, the hearsay you heard is actually true!
PFSard
Mesa, AZ
Cyanoacrylate
http://en.wikipedia.org/wiki/Cyanoacrylate
I found this interesting. Some information below from Wikipedia. All the usual disclaimers.
2-octyl cyanoacrylate (used in medical, veterinary and first aid applications). Octyl cyanoacrylate was developed to address toxicity concerns and to reduce skin irritation and allergic response.
CA glue was in veterinary use for mending bone, hide, and tortoise shell by the early 1970s or before. Harry Coover said in 1966 that a CA spray was used in the Vietnam War to retard bleeding in wounded soldiers until they could be brought to a hospital. Butyl cyanoacrylate has been used medically since the 1970s. In the US, due to its potential to irritate the skin, the U.S. Food and Drug Administration did not approve its use as a medical adhesive until 1998 with Dermabond.[9] Research has demonstrated the use of cyanoacrylate in wound closure as being safer and more functional than traditional suturing (stitches).[10] The adhesive has demonstrated superior performance in the time required to close a wound, incidence of infection (suture canals through the skin's epidermal, dermal, and subcutaneous fat layers introduce extra routes of contamination),[10] and final cosmetic appearance.[11][12]
Some rock climbers use cyanoacrylate to repair damage to the skin on their fingertips.[13][14] Similarly, stringed-instrument players can form protective finger caps (in addition to calluses) with cyanoacrylates.
While standard "superglue" is 100% ethyl cyanoacrylate, many custom formulations (e.g.,, 91% ECA, 9% poly(methyl methacrylate), <0.5% hydroquinone, and a small amount of organic sulfonic acid[15] and variations on the compound N-butyl-cyanoacrylate's for medical applications[10]) have come to be used for specific applications.
The United States National Toxicology Program and the United Kingdom Health and Safety Executive have concluded that the use of ethyl cyanoacrylate is safe and that additional study is unnecessary.[19] 2-octyl cyanoacrylate degrades much more slowly due to its longer organic backbone that slows the degradation of the adhesive enough to remain below the threshold of tissue toxicity. Due to the toxicity issues of ethyl cyanoacrylate, the use of 2-octyl cyanoacrylate for sutures is preferred.
xs650shawn
Hesperia, CA
Medical version called Derma-bond. Standard CA glue. Cannot remember the last time I used CA glue on a cut, but the New Skin brand-warning- stings like a bi#*%!
Super Mech
Bronx,NY
I've used it many times for split finger tips from the cold weather. It works great and stops the pain almost instantly.
Jason280
I've used it exclusively for at least five years. I'm in the medical field, and small nicks/cuts on your hands are a big risk. I keep at least two tubes in my locker at all times!
BajaBound
Nor Cal
Make sure to clean the cut very well with soap and water and then diluted paroxide as you are trapping anything and everything inside the wound. Yes it used in the ED but it's medical grade and sterile.
49tandc
Gainesville Florida
I had a complete knee replacement & the skin was glued back - no stitches or staples.
Doc made some sharpy reference lines & glued the corresponding lines together. I'm a firm believer in CA glue for skin. I keep it in all of my toolboxes.
49T&C
2ndGearRubber
Pittsburgh
Having worked in a sub shop with a deli slicer, super glue saved a few finger tips. Much cheaper than going to the hospital, since most employees didn't have any sort of health care. Keeps infections down too, when you add a second layer after the bleeding has stopped and the first layer to secure the remaining skin has set up.
fury9
Mchenry, IlLaHnoYs
I used it on a cut on my fingertip and it got infected, hurt like hell, had to cut it open a few days later and squeeze the goo out. I use the good ol electrical tape and a paper towel method usually. To each his own though
sbyrne92
I had friend who split his head open after falling into a table, while drunk. We superglued his head shut, which stopped most of the bleeding till we made it to the hospital….college was a hell of a time
IOWNJUNK
Cut hand and finger. Superglue is great, use latex gloves or you'll glue your fingers to the cut.
rancherbill
Foothills County, Alberta, Canada
Cyanoacrylate is a family of chemicals.
Butyl cyanoacrylate is the real medical one.
Methyl 2-cyanoacrylate is Krazy glue.
They are not the same, but they are close enough for me. I use Krazy Glue all the time for cuts and ESPECIALLY for winter dryness cracks on my hands.
Hornman
Southwest DFW
I've used this stuff for years...
New Skin is not a "super glue", no cyanoacrylate content. That said, I do keep a bottle in my first aid kit.
New Skin Liquid Bandage
Active ingredients
Benzethonium Chloride 0.2% First Aid Antiseptic
Inactive Ingredients
amyl acetate, benzalkonium chloride, castor oil, clove bud oil, ethyl alcohol, n-Butyl acetate, nitrocellulose
nicksnothereman
In the Mojave
Nah. Just run of the mill super glue.
That's what it was developed for. But...not for everyone. You don't clean the wound right before application (and it's deep enough) you'll probably have a bad time. I doubt people in general put themselves in situations that require more than a band aid and neosporin.
The reason for field use of super glue is because you can keep doing what you're doing whereas a band aid will come off (they have glue type band aids that are better for this). Lighter and super glue is all I would ever need (usually don't need the super glue) for bleeding wounds. You can do this but I don't recommend it if you still feel pain.:bounce:
General Geoff
Allentown, Pennsylvania
Love cyanoacrylate for closing up lacerations big and small. I've cut open my wrist pretty bad (3" gash that went down to muscle, got it from a nearby hose clamp when I broke loose a stubborn manifold bolt) that would definitely have required stitches, had I not used super glue to keep the wound closed while it healed. I must have done a good job because there's only a barely-visible scar that you have to know is there to see. Same excellent results with a pretty deep x-acto knife wound on the hand, and various other smaller/lighter wounds over the years.
BlackjackNA
Newfoundland, CANADA
I'm always cutting my fingertips - this will definitely replace the paper towel / black tape remedy from now on. Thanx!
(Side note: duct tape cures worts)
Professur
Mo-Ray-Al, K-bec, Ka-Na-Da
This above all. You definitely don't want to seal in **** and have it balloon up with nice red streaks up after a couple of days.
K
Kin Creed
Minneapolis, MN
Thanks for all the responses, good info here!
I was always a little skeptical of New Skin type treatments for cuts because I once had a covered cut get infected and as was mentioned my finger got really big, discolored and it was even hot with infection. The doctor said I came in just in time to save myself some serious grief not only with my finger but the infection spreading to my bloodstream and doing a lot of other bad things.
So I try to clean up my cuts at night and let them "breath" in an attempt to make sure no bad stuff is trapped under the skin to cause infection. Anyway, I think as long as you clean the cut, glue seems like a pretty good option. And especially for cracked skin where infection is not as much of a concern.
Kirbot
New Jersey
The Dr closed this up for me with 3M tape and glorified super glue. No stitches.
So, yeah... It works pretty well.
