moss
Status
Not open for further replies.
BADSIX
oregon coast
ok, I want to hear your moss removal remedies. I've searched google but its just full of commercial stuff that's harmful to animals. I did read about Tide washing soap has anyone used this? the moss is really bad here this year plus I have a lot of roof area and drive way. I used Moss-Be-Gone a few years ago but now its so bad that i'll need a pickup load of it. THANKS!
Jay D.
cruzer75
Interested also as our insurance changed and the inspector pointed out my moss on the roof
CNGsaves
KS and OK
Where are you located ??
Now would be good time to Update GJ Profile with City / State.
Lots of problems when roof remains in shade and stays wet. Just was talking with roofer couple weeks ago, and they have one-time treatment they spray on that is supposed to last 10 years. Or homeowner could spray periodically with diluted bleach.
Be sure to get shingles that are Algae Resistant.
AnthonyJ124
Southeast
I use powdered tide. Throw a good dusting all over the area a few days before it rains and it'll kill the moss- you'll see it yellow. Then I go up with a light broom and/or pull off clumps by hand to clean up. After a few treatments and I'm 80% better. Doesn't kill any grass of plants at least on my property.
I'll likely try a moss specific product in the spring or possibly bring in a roof cleaning company...
larry_g
oregon
Chemistry teacher related this story years ago. He was getting moss on his patio so went to get some killer. Reading the contents most of them were copper sulfate. So he went to the bank and bought $10 worth of pennies and scattered them around. They did the job and the next year he let the grand-kids pick up the pennies and turn them in.
lg
no neat sig line
theoldwizard1
SE MI
I had terrible moss in one of my flower beds. I would scrape it off in spring and would just come back.
Last spring I got pissed. 1 cup of bleach to a gallon of water in a pump sprayer. After a week, most of it was still there. 2 cups per gallon. Repeat weekly until it is gone.
BADSIX
oregon coast
thanks for the replies, I will probably go with the moss out or moss be gone on my roof. the run off go's out to the road then into a brush field. I don't want to use it on the drive way and have the dog get in it. it also might be hard on the lawn down the edge of the drive. I think i'm going to try the Tide on the drive way.
Jay D.
Vegaman_Dan
Pacific, WA
Locally the home improvement guys on the radio suggest cheap laundry detergent. Spread it around at the top and let the rain take care of the rest. I've seen the results and I'm a believer.
marinusdees
Edgewood, Washington
Use Tide WITH bleach. Not Tide and bleach. Sprinkle it lightly everywhere you want the moss gone. Don't assume it will run down from the peak of the roof. The bleach kills the moss. The Tide holds the bleach where you put it. On the roof, with any pitch, the moss will disappear. It will die. On flat surfaces an alternative is to spray with Purex diluted 50/50 with water. It won't work on slanted surfaces as well since it runs off. This is as environmentally friendly as you can get. I live in Washington so I know what your problem is. If you don't believe me, find a professional roofer and ask them.
kbs2244
The copper wire along the ridge is the classic solution.
I do like the pennies spread on the roof though.
The same effect and undoubtedly cheaper.
rburke65
Canfield, Ohio
Had moss on my shed roof and I attacked it with a pressure washer and it came out great…I only used water…no soap or whatever
pcmeiners
Be carful with bleach, 50-50 mixture is too strong. I used water4-1 bleach and that still changed roof color. As to copper sulfate works great. I sprayed a mixture of 8oz copper sulfate (purchased on Flea bay) to 2 gallon water, than I sprayed a diluted bleach solution on the roof immediately after applying copper sulfate. This displaces copper in the sulfate, which leaves colloidal copper metal embedded in the shingles, unnoticeable but should last years to stop moss from growing.
Status
