quality c clamps
nickb
southeast FL
I would like to find some good quality c clamps. I have been looking for used ones, but the only ones I have been able to find were really worn out.
Does anybody have a recommendation for a good new USA made c clamp? I'm looking for something 8 inches or larger.
rlitman
Long Island
Wilton makes top notch C clamps. Forged steel is the way to go. Cast iron clamps do not compare.
sberry
Brethren, Michigan
Sometimes there is no good way around it. Buy what you need one at a time and keep an eye out. I actually had someone give me these. It kind of topped off my set. Something worth spending on is Vise Grip 11R. When people ask what you want for Christmas put that on the list. I caught a sale at as flea and even after all these years topped up with a couple.
These types of clamps are very good because they are very universal. They work on the job and on the bench and its hard to get too many.
Having enough clamps allowed tacking or welding some out one shot. I put a laborer on a job a while back,,, peck peck peck with the feeder and I go back and set the job up with a clamp to make the weld vs several tacks.
u118224
Northern MI
They must really beat on stuff at the ole farm. Any farmer I've known never babied their equipment.
sberry
Brethren, Michigan
The job above was actually for the snowmobile club. The part they got was missing 3 ears and some other attachment. Every once in a while we break something. Its fairly rare I the grand scheme of things but we do a lot of bit modification. I aint scared to stop and fix a bracket, drill a new hole etc.
Anything I can weld on to make something easier I am all over. 10# of wire can last me a long time in my little feeder if I am thrifty but makes hundreds of small welds.
rlitman
Long Island
Kant-twist is an interesting point. Not really a C clamp, but for many uses it can substitute as one (and is superior in some ways).
exmaxima1
Midwest
Kant Twist if you need very high holding force. Vise Grip welding grips (especially the ones with the swivel feet) for the other 90% of the time.
PT Doc
Kant twist. So many sizes. Pin handles or knurled know for the smaller ones. At 30% off at enco, they are a steel.
Steevo
43.49600, -112.04300
I use welding clamps far more often than C-clamps, and I have plenty of each.
And I don't mean the HF cheapo's, either. They are junk.
dr_clyde
Holland, MI
My go to clamp is the strong hand sliding bar clamp. I've got about two dozen. I love em.
If I need really strong clamping force, I switch to c clamps. New, I like Wilton and Armstrong. Used, I'm a fan of Williams, Grand Tank, and Billings.
Repeatable, one handed clamping I use 11SP vise grips.
sberry
Brethren, Michigan
I have used the Bessy type bar clamps, they are ok but wouldn't trade common ones for them. A guy might have a kant or 2 if he was repairing damaged steel.
