I have been up a few times working on the new place, but as usual, life gets in the way. I am getting my old houses wiring updated (removing the knob and tube and upgrading the fuse box to breakers and a 100amp service) and been playing tag with the electricians. I need to get this house done, listed, and sold to have funds to reno the new place.
Anyways, after taking some time to inspect the place I found a couple of issues that needed immediate repair and that has been what I have been working on. I am adding a gas forced air furnace for the apartment and commercial space, and found that where I am building the furnace room, the floor was very springy. Like trampoline springy. This area was where they used to keep bagged feed - 10+ tons of it. I think it should be a little more solid. Measuring showed the floor was not anywhere close the level and had a 2" slope towards the end of the room.
Popping down into the crawl space revealed that three of the block pillars supporting the end of the main floor had sunk or fallen over. The entire floor was just hanging out in space. Not good. A little digging revealed an entire concrete floor under an inch or two of dirt (that had fallen through he T&G pin floor over the years) with concrete footers under the support pillars. I guess the original contractor was running low on material because the footers went from a solid 4" down to about 3/4" at the end where the pillars had fallen over, and I didn't find any rebar. The pillars had punched right through the thin footer and sunk several inches with the weight of the feed on the floor.
I ended up pulling up all the 1" T&G pine flooring, digging out the broken footer, pouring a 6" thick footer back up to floor height, rebuilding the block pillars with double the block to spread out the weight over a larger area, sistering up the floor joice since I didn't trust them after being bent like they were for years, and leveling and resheathing the floor. I used 5/8" T&G OSB, with a 3/8" underlayment board to equal the original 1" pine boards. I am going to put linoleum down before the furnace goes in since this room is also the interior entryway to the shop.
Here is my nephew giving me a hand laying the underlayment board. Lots of screws in that floor. The area replaced is about 10'x10'. There will be a 2x4 non structural wall going up where the new floor meets the old.
View of the pile of old flooring. I think it is destined to become firewood. The entire floor is pretty loose from all the weight that was put on it.
Now I know you guys wanted to see the shop. I could easily fit 6 cars in here.
I moved the 67' Belv here a few weeks ago.
Here is the main floor from the side entrance. The stairs go up to the unheated storage area above the shop and the apartment. I have a lot of sheetrock to put up.
Did I mention I have a lot of storage space right now? This area is 40' x 40'.
Next up - the apartment.
