Snap on ratchet loose
uk-doctor
I have the dual 80 series ratchets T72 & F80 they are both brand new and i love them to bits, but i carnt help but notice that the drive that goes into the socket/extension is quite loose on the F80 causing a lot of wobble. Also the T72 when i fix it to a socket the socket wobbles all over the place, the socket doesnt drop off but is just very loose!
Should the socket not be securely tight in place, and the ratchet drive solid in position?????
Buckgnarly
VT
All of mine hold sockets TIGHT, and none of them wobble on the male drive end. Part of the reason I prefer them to others is how tight the drive end is over Matco type designs. Rebuild kits or check with your driver.
U
uk-doctor
cheers mate i posted a thread on a tool discussion forum to gather users advice, not to be education in spelling by some smart **** thankyou thow
U
uk-doctor
even the T72?? the socket does not wobble at all? cheers
tweedlestan
Palmdale, CA
Every T72 I've seen wobbles.
Although I believe you're referring to the socket not fitting tightly on the square drive? If so, that would have more to do with the detents on the sockets themselves.
U
uk-doctor
is this deliberate or? i would of thought they should hold sockets solid upright with no wobble atall
mensa
San Francisco, Ca
....and make sure you attend English classes. They're important.
Trony, Trony, Trony............:D
Trony got told. :D
The ratchet drive end shouldn't be loose or sloppy on the Snap on ratchet. Maybe just a little play if you wiggle it hard, but not sloppy like a craftsman quick release.
stovebolt6
Canada
Could be the sockets. Sockets are much more susceptible to inconsistencies than ratchets are.
Buckgnarly
VT
Stick around long and enough and you learn to ignore certain members you post useless and often incoherent ****...:thumbup: There is even an ignore feature so you don't even have to see it, if only life could have that feature:bounce:
U
uk-doctor
haha i will mate, its not causing a problem but for the money you pay for snap on you expect everythink to be secure and strong
U
uk-doctor
1/4'' deep, 8mm - 15mm all the same, if you put one on and hold the ratchet vertical the socket will droop
Cope
Houston, TX
All of my ratchets, Snap on and others, have some play in the head. Every Proto I have handled has play in the square drive, both male and female ends.
Bigblue&Goldie
I agree the 1/4" might have a little play, but all 5 of my 3/8" are all really tight. What brand sockets?
