whitedogone
- Joined
- Jan 20, 2014
- Messages
- 230
Picked up some lowes 5/8 gromments....fail....maybe I got the wrong ones....don't know.
McBrownie,
Apparently you are unaware or wish to ignore certain copyright laws by defacing original publication photos. I as a model citizen googled that image and was able to get permission to repost this image. The author was kind enough to email original studio shots of the original conceptual design. Below is proof I'm full of s%$#.
How about the worklight, says 30w max. What about a brighter one....say led.
McB & ALL: some of us really liked McB's Black and Decker workmate grinder stand and i just found an accessory for him and us. in case we need a flat top i'm sure we all could have thought of this, but pictures always help me so posting it here.
I guess I have a block as well. It has been sitting in a box in the attic of my garage for the last 10 years. It has always seemed to vibrate quite a bit since new. Maybe I should try to figure out what's wrong with it if anything.
Tried using hockey pucks to keep my grinder from walking away from me. The hockey pucks turned out to be a marginal improvement. So I cut out a piece of plywood and glued a antifatigue mat to the bottom. Much more surface area and works wonderfully.
I got into mine tonight after work. a few observations:
1. The shafts have little runout (no more than .001)
2. The armature doesn't have any end play or radial play
3. The armature does not spin as freely as I would think (but no "bad"bearing feel) just bearing drag.
4. The "cooling" fins on the armature seam to have a huge amount of "out of Round-not centered" when spinning the shaft. About 1/8" at least. Is that normal?
Is there any need to take the armature to a motor shop and have them balance it? It just really seams to vibrate a lot more than other quality grinders I've used. Also, anybody have a link to decent wheels? How about the worklight, says 30w max. What about a brighter one....say led.
If the grinder is still vibrating without any wheels attached, then I would look into that. However, try it without wheels first. I've never heard of anyone needing to balance the armature.
I always had a concern about the hockey pucks. I mean they make excellent feet for a table/base without an excessive vibrating machine mounted to it. But hockey pucks were designed to glide across ice. IMHO, they wouldn't make a suitable anti-vibration isolation foot for a heavy vibrating machine like a grinder or such machine.
I feel like I need to take a moment to mention that the rotor in an induction motor is not an armature. Technically, the stator windings are both field windings and armature windings.
Yep.![]()
Heads up if anyone's interested. Was checking out my local CL and noticed this 3/4 HP Flat-Top...for $20. It looks like it even comes with all the little bits that are normally missing. It's in Mansfield, OH. I'm sick and don't really feel like driving out there, but I figured someone here might be interested.
http://mansfield.craigslist.org/tls/4805401995.html
That IS within my swooping range!Someone from Ohio hurry up and get that before TM swoops down from up north and steals it from us.![]()
I eMailed 2 of the members on the Want List. I hope one of them is able to ****** it up.
I'd be headed down there for it (to get it for a GJ'er), but I got some bug in the germ pool that Delta calls an airplane last week end!
Somebody please get it.![]()
Thanks torque and leadberry for posting i grabbed it
) But, I love it. I'm glad it went to a GJ member.
Are you planning on giving it "the treatment"?Tedsters: we have a great group here don't we? nice score on that 3/4 HP for $20 because it should clean up nicely.
TM: thanks for the heads up and i hope you feel better.
Congratulations on that big 3/4hp. Same price I paid for mine (before I dumped a whole bunch more into it.) But, I love it. I'm glad it went to a GJ member.
What should we be calling it? A rotor?
Although, if this gooseneck is the same length, I'll just repaint it and replace the original. Phase 3 just keeps growing in scope!
View media item 46094
Here is a question. The first picture is from a Block that Torqueman posted a while back. It is a model 397.19670 but does not say "Industrial Rated".
View media item 46144
Here is mine with the same model number, but does say"Industrial Rated".
View media item 44807
Anyone have a clue when they stopped or started using the "Industrial Rated" term? Does this make my Block better than TM's?![]()
I'm curious what technique y'all are using to paint your goosenecks. Since it flexes, I've been assuming that any paint job I do will look like **** the first time I move the neck. I was just going to settle for de-rusting mine and hitting it with floor wax over the bare steel, but if there's a good way to paint it, I'd rather do that.
I'm pretty sure the Industrial Rated and Commercial designations are the same thing. My early 60's block is an Industrial, whereas my early 70's block was a Commercial. I'm guessing your block is from around the time they switched over. Late 60's right?
Same here about the gooseneck paint. For the grinder I did on post 3382
I ran scotch brite over it, then prep-all (auto body paint prep) and then a very light coat of paint. It seems to be fine. During use you actually move the gooseneck very little and each individual "winding" of the gooseneck moves very little.
Greg,
Do you still have that awesome B&D stand from post #222?![]()
You're welcome!Tedsters: we have a great group here don't we? nice score on that 3/4 HP for $20 because it should clean up nicely.
