80WTI_55_CHEV
bundamba australia
Built a rocking chair for the wife for christmas, similar to the one at the big Texan steak house.
Carves
Central West NSW .. Australia
A major achievement .. :rocker:
I finally provided justification to the Minister of Cooking and Finances - for the purchase of some, of the tools bought in past months.
NWS Fantasticos,
A few StrongHand clamps,
New hammer handles,
Over the next few months I will be casually mentioning, .... repeatedly,
... Coulda fixed that laundry trolley a lot sooner .... if I had a brake press .. :D
zmotorsports
Northern Utah
Last night I watched my son machine a resonator plug for his Duramax. Tomorrow I am going to help him bore out the turbo intake/snout. It was the first time he has been able to use our new lathe and it was fun to watch him. He has been so busy working and with school I haven't had much time to work with him in the shop the past couple of months.
Mike.
rmalkow2
Brighton, MI
Assembled a HF trailer dolly. At first I thought I really should have made my own from scratch but it was on sale and I had a 25% off coupon to boot. I don't think I could have duplicated it for the same $$.
TurboMustang370
Central, New Jersey
keep an eye on it. I just saw a HF tow dolly spit a wheel and assembly goin down the highway the other day. The tire bounced and passed the truck that was towing the dolly at 65mph.
rmalkow2
Brighton, MI
Let me know if you think it is modifiable to take some fairly big tires. I can't think of a need for one right now but I always wondered if the dolly could be converted to a slow speed kind of steering trailer./wagon axle.
It has I think a 1/2" axle so you could probably swap out the stock wheels for something a little larger but the frame of this thing is pretty light weight. So depending on the size of the trailer you want to steer it might be too light duty. But if you really mean "slow speed" this could be adaptable. For manually moving around my trailers in the driveway it worked perfect today. I hand moved both a very light 9' flat bed trailer and a heavier 6 x 12 enclosed trailer with a lot less effort than lifting the tongue's by hand.
rmalkow2
Brighton, MI
Sorry for any confusion with my original description. I think you are talking about a tow behind dolly for hauling a vehicle? This is just their simple hand truck dolly for moving trailers around the yard by hand. It worked very well today and was much easier than lifting trailer tongue's
TurboMustang370
Central, New Jersey
My apologies, I thought you were talking about a tow dolly.
wagzilla
Arizona
I used my new strut compressor.
Wow was it hard to reinstall in the truck
Glad I'm done
James
Steevo
43.49600, -112.04300
Today I decided to clean up the growing mess in the corner by my welding table. I have been sticking cut-offs in a bucket or a bin, and they have overflowed the capacity of those receptacles.
I picked up a steel bookshelf to use in my re-organization schema:
I cleaned out the corner:
And mounted the shelf to the wall, sitting on the foundation ledge.
I used some angle inside the back of the top to support the cabinet:
And I also screwed the back panel to the studs at the middle.
Then I fitted my Akro bins into the shelves.
I had to notch them to get two across:
And I organized my metal drops by type (round, tube, square, angle, etc.), in the bins:
And I made up a couple of wall brackets for some of the longer stuff:
Now I have less clutter and it is easier to find what I need:
vertguy
SE WI
Continued the tear down and clean up of a recently acquired Sears Dunlap bench drill press. Fabricated a cover for the motor electrical connections and have the main support pipe soaking overnight in Evapo-Rust. Should be sparkling clean by the morning.
MoparTrucks
Ozarks of Missouri
Looks much better Steevo and I am glad to see you chained your tank....reminded me I have some securing to do of my own.
Dennis Leigh Henry
South Central, IN USA
Steevo..!! Super cool and well done..
BonzoHansen
Wrapped up putting a new Briggs motor on my snowblower, replacing the broken rod Tecumseh engine. Just waiting on some parts from toro for the trans controls.
old crewcab
Sitting down and relaxing on the couch this evening and my wife casually mentions "My car wouldn't start today. When it did and I tried backing out of the parking space it stalled. Could you do something about that?"
I'm like WTF? When where you planning on telling me about this? Got it started and into my garage. The idle air control valve was all cruded up with carbon and I'm assuming the problem. Got it all cleaned up, but can't test until tomorrow when I pick up a new gasket.
Was curious if the IAC valve fixed your problem? Our van is having starting issues, and I was suspecting valve as well. Thanks
Backpack Hunter
NC
Tore down the Neon. Found a cracked head. All in all it needs around $1500 in parts plus my time with around 187K miles on it. Trying to decide if it is worth it to repair or if it is time to replace.
wyo george
Wyoming, USA
Changed the oil in the Subaru and Chrysler then worked on some more cutting boards for Christmas presents. Almost done with presents for this year.
Dennis Leigh Henry
Working to restore / touch up the flammables storage cabinet I purchased at auction last night.. $50.. 18x43x44.. Had to scrape/sand/prime/paint the rusted lower portions, and bottom inside shelf (picts are upside down in garage where I did the prep work). The final coat is drying in my basement where it will be used to store my paint thinners and other oil based materials.
I'll post pictures when all through.
Dennis
